Home > Technical > Battery Light, No Rev Counter and Temp Gauge at the top?
Page 2 of 2 <12
DeCA
Belgium 2007 Defender 90 Puma 2.4 SW Barolo Black
Hi, I cleaned everything, stil have de same problem!
Even I reconnected de the brand new battery..
Post #855655 12th Sep 2020 3:02pm
unclesam
Poland 2008 Defender 110 Puma 2.4 SW Cobar Blue
So you dont have anything OBD-connected and you still get issue described in this thread?
Post #855914 14th Sep 2020 6:54am
DeCA
Yes indeed!
Post #855924 14th Sep 2020 8:03am
unclesam
To me this clearly looks like communication issue between ECU and Instrument cluster
There is nothing else connected to the bus except of above two.
I would then check wiring between Instrument Cluster and ECU.
First I would check ECU plugs. In my Puma there were signs of oxidization on some of the pins.
Post #855926 14th Sep 2020 8:07am
DeCA
OK, i will do the check!
To be sure:
ECU, where do I find these.
Are the wires from the instrument-cluster al together.
I have an manual of my 2007 but to bid to find....
Thx!
Post #855931 14th Sep 2020 8:31am
unclesam
Wires are bundled in the loom . If there is a pitfall that's going to be challenge.
But first check ECU plugs. ECU is in the middle of engine bay handing on bulkhead.
Be gentle, dont break anything Smile
Post #855934 14th Sep 2020 8:43am
Martin
Site Admin
The CAN bus wires are on the brown coloured ECU plug.
Do you have a multimeter you can use to do some basic resistance checks?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #855943 14th Sep 2020 9:21am
DeCA
I recently bought a multimeter, so I check the brown plugs with a beep test?
Post #855950 14th Sep 2020 9:54am
unclesam
you should check wiring continuity on respective PINs between ECU and Instrument cluster (the PINs that are for CAN connectivity ) .
You will need eletrical manual for puma and some medium knowledge of car and electrics.
If you have doubts , guess you need to visit some workshop.
Post #855952 14th Sep 2020 10:07am
Martin
Site Admin
With everything still plugged in, use your multimeter in resistance setting to measure across pins 6 and 14 of the OBD port:
(ignore pin 4 at the moment)
You should measure around 60 Ohms  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #855960 14th Sep 2020 10:37am
Page 2 of 2 <12
