![]() | Home > Technical > Battery Light, No Rev Counter and Temp Gauge at the top? |
DeCA Member Since: 18 Aug 2020 Location: Vlaanderen Posts: 8 ![]() ![]() ![]() |
Hi, I cleaned everything, stil have de same problem!
Even I reconnected de the brand new battery.. |
unclesam Member Since: 09 Dec 2018 Location: Krakow Posts: 13 ![]() ![]() ![]() |
So you dont have anything OBD-connected and you still get issue described in this thread?
Yes indeed!
OK, i will do the check!
To be sure: ECU, where do I find these. Are the wires from the instrument-cluster al together. I have an manual of my 2007 but to bid to find.... Thx! |
Wires are bundled in the loom . If there is a pitfall that's going to be challenge.
But first check ECU plugs. ECU is in the middle of engine bay handing on bulkhead. Be gentle, dont break anything ![]() |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6641 ![]() ![]() ![]() |
The CAN bus wires are on the brown coloured ECU plug.
Do you have a multimeter you can use to do some basic resistance checks? ![]() ![]() |
I recently bought a multimeter, so I check the brown plugs with a beep test?
you should check wiring continuity on respective PINs between ECU and Instrument cluster (the PINs that are for CAN connectivity ) .
You will need eletrical manual for puma and some medium knowledge of car and electrics. If you have doubts , guess you need to visit some workshop. |
With everything still plugged in, use your multimeter in resistance setting to measure across pins 6 and 14 of the OBD port:
![]() (ignore pin 4 at the moment) You should measure around 60 Ohms ![]() ![]() |
