Home > Puma (Tdci) > Puma indicator and theft advice
Page 3 of 4 <1234>
Lorryman100
@T1G UP Thumbs Up
Post #402239 25th Feb 2015 10:59pm
munch90
If you got the bbus fitted that prevents that ?
blowing fuse trick goes way back to the xr3i days
Post #402247 25th Feb 2015 11:09pm
Jamie W
United Kingdom 2009 Defender 90 Puma 2.4 HT Galway Green
any chance of a pm please?
would be much obliged Very Happy
Post #402250 25th Feb 2015 11:15pm
NickH
England 2003 Defender 90 Td5 PU Rimini Red
Ok
I have thought about this and rather than loads of pm's I will explain what I will be doing to safegaurd my next puma without giving away anything to thieving scroats.
1, protect or move your alarm horn/bbus, fit a metal box with sound holes over it or move it somewhere else away from the factory position.
2, Find the 2 wires that go to the n/s/f indicator, cut the coloured wire as far away from the indicator as possible and join some twin core wire to each end, run the wire into the cab and fit a hidden switch. Turn the switch off whenever you leave the defender parked....dont ask why, just do it
3, fit bolts to secure the under seat access panels,(battery and fuse boxes) use rivnuts into the seat box and bolts with round/torx/anti tamper heads and plenty of them.
4, If you dont want to move your alarm/bbus then fit some light gaurds with anti tamper bolts.
5, if possible park the front end against a wall.
Unless they come and winch it away, your puma will stay where it is if you follow these simple things....and no one will know you have done it Thumbs Up 2003 Td5 90
2013 sport hse
2012 700 raptor quad
2012 siromer 4x4 tractor
Post #402259 25th Feb 2015 11:33pm
Al_The_Pal
2015 Defender 110 Puma 2.2 XS CSW Corris Grey
Thank you, very informative, simple to follow and give little away Thumbs Up
Post #402273 26th Feb 2015 12:01am
Jamie W
NickH,
Thanks very much for the info.
Post #402296 26th Feb 2015 9:16am
ibexman
PM please
Post #402297 26th Feb 2015 9:21am
Rickydodah
Thanks NickH Bow down I started with nothing and still have most of it left!
Post #402325 26th Feb 2015 10:53am
General Grabber
PM too please.
Thanks.
Post #402333 26th Feb 2015 11:34am
Dean Watson
United Kingdom 2011 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
Pm
Pm please if possible
Post #402498 26th Feb 2015 8:21pm
noworries4x4
After my 57 plate 2.4 was attacked plenty of info on here re this, my solution was to fit led indicators all round and run 2.5amp fuses in the indicator systems and uprate the alarm ones to 15amp thieving scrotes can do what they like to my indicator wiring now. As for the seat boxes I have padlocked mine with small hasp and staples. If everything is under control you are not going fast enough.
Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle
Weekends 07MY L322 TDV8 Vogue SE
No Worries 4X4
Post #402614 27th Feb 2015 12:03am
salesman
United Kingdom 2008 Defender 110 Puma 2.4 CSW Zambezi Silver
if it applies to a td5, PM please..
Post #402640 27th Feb 2015 9:15am
Tiger
Yes it applies to TD5
However the PM won't tell you anymore than is already in this thread.
Just follow what NickH said.
Thumbs Up
Post #402641 27th Feb 2015 9:24am
scotia
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Corris Grey
Withdrawn after reading subsequent posts.
Post #402660 27th Feb 2015 10:41am
NickH
Another cautionary note to all defender owners, Exclamation
Having dealt with many stolen recovered defenders and seeing cctv footage of defender thieves in action I would confidently say that a standard defender puma/td5 with a factory alarm can be stolen/ driven away in under 3 minutes easy.....how frightening a prospect is that Shocked
So for anyone debating extra security please please do it, spend a little bit of time and money and you should be able to hang on to your pride and joy no problem. Thumbs Up 2003 Td5 90
2013 sport hse
Post #402717 27th Feb 2015 1:16pm
Page 3 of 4 <1234>
