![]() | Home > Puma (Tdci) > Puma indicator and theft advice |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
@T1G UP
If you got the bbus fitted that prevents that ?
blowing fuse trick goes way back to the xr3i days |
Jamie W Member Since: 28 Mar 2012 Location: Herts Posts: 32 ![]() ![]() ![]() |
any chance of a pm please?
would be much obliged ![]() |
Al_The_Pal Member Since: 09 Feb 2015 Location: Near the bottom on the right Posts: 146 ![]() ![]() |
Thank you, very informative, simple to follow and give little away
NickH,
Thanks very much for the info. |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2963 ![]() ![]() |
PM please
Rickydodah Member Since: 14 Jul 2014 Location: East Sussex Posts: 1091 ![]() |
Thanks NickH
General Grabber Member Since: 27 Dec 2013 Location: Mos Eisley Posts: 49 ![]() |
PM too please.
Thanks. |
Dean Watson Member Since: 17 Jul 2011 Location: Derby Posts: 263 ![]() ![]() ![]() |
Pm please if possible
noworries4x4 Member Since: 24 Dec 2010 Location: Newton Abbot Devon Posts: 1195 ![]() ![]() |
After my 57 plate 2.4 was attacked plenty of info on here re this, my solution was to fit led indicators all round and run 2.5amp fuses in the indicator systems and uprate the alarm ones to 15amp thieving scrotes can do what they like to my indicator wiring now. As for the seat boxes I have padlocked mine with small hasp and staples. If everything is under control you are not going fast enough.
Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle Weekends 07MY L322 TDV8 Vogue SE Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
salesman Member Since: 01 Sep 2014 Location: The Yorkshire Dales God's Country Posts: 72 ![]() ![]() ![]() |
if it applies to a td5, PM please..
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 ![]() ![]() |
Yes it applies to TD5
However the PM won't tell you anymore than is already in this thread. Just follow what NickH said. ![]() |
scotia Member Since: 29 Oct 2014 Location: North Cambs Posts: 96 ![]() ![]() ![]() |
Withdrawn after reading subsequent posts.
NickH Member Since: 02 Nov 2014 Location: Halifax Posts: 204 ![]() ![]() ![]() |
Another cautionary note to all defender owners,
![]() Having dealt with many stolen recovered defenders and seeing cctv footage of defender thieves in action I would confidently say that a standard defender puma/td5 with a factory alarm can be stolen/ driven away in under 3 minutes easy.....how frightening a prospect is that ![]() So for anyone debating extra security please please do it, spend a little bit of time and money and you should be able to hang on to your pride and joy no problem. ![]() 2013 sport hse 2012 700 raptor quad 2012 siromer 4x4 tractor |
