Home > Technical > Safari Snorkel Removal |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20564 |
There is no pipe work involved as far as I am aware behind there.
23rd Feb 2015 12:23pm |
capnjapseye Member Since: 21 Feb 2015 Location: Cornwall Posts: 223 |
Thanks for the info
I should find out soon, hopefully get the car tomorrow or Wednesday |
23rd Feb 2015 1:06pm |
SailingTom Member Since: 19 Nov 2013 Location: ESSEX Posts: 1722 |
If its a genuine safari you'll probably need the first plastic pipe section as the come with a replacement hose to use instead if its been fitted properly.
Hope this helps Defender puma dormobile camper |
23rd Feb 2015 1:24pm |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 |
If you're selling the snorkel after you've removed it I'd be interested and I'm also in cornwall so could collect it.
23rd Feb 2015 2:42pm |
Hi Roy
Just spoke with Carrs & will be collecting the Defender tomorrow PM. The snorkel is a Safari one and it will be for sale once removed. If you can PM me your number, I'm only 15 mins from you. Cheers |
23rd Feb 2015 4:47pm |
Cheers for the info Tom It is a Safari one, or at least it says so on it. Therefore I reckon I might need the first hose section as you say. Maybe I can sort this with Roy as it looks like he wants the snorkel. Cheers |
23rd Feb 2015 4:49pm |
x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327 |
As far as I can remember, the Puma one doesn't come with a flexible hose, it just attaches to wing and then feeds into the existing ducting the other side of the wing aperture. Remember, it's a Raised Air Intake and not a snorkel, so doesn't come designed to be fully waterproof.
All that should be required is to remove it, refit a grill and then full the holes on the wing and windscreen pillar. Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography Last edited by x-isle on 23rd Feb 2015 5:15pm. Edited 2 times in total |
23rd Feb 2015 5:13pm |
Its a quick job and roy will have to remove it to fit so sounds like you both have it sorted as a nice swap while your there
Edit I might be wrong about it but there was on mine as Safari is sold as a proper snorkel I beleive Defender puma dormobile camper |
23rd Feb 2015 5:14pm |
Here's a video of installation;
It's not the snorkel that's not waterproof, it's the fact that the whole airbox and ducting needs to be fully sealed. Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
23rd Feb 2015 5:23pm |
I've pm'd you bud.
23rd Feb 2015 6:31pm |
PM recieved will be in touch
Cheers |
23rd Feb 2015 7:09pm |
4wheeler Member Since: 13 Apr 2010 Location: Melbourne Posts: 87 |
The Safari snorkel for that model uses the Land Rover ducting. If it had been installed as per the instructions, sealant should have been used between the snorkel body and the second sealing gasket which fits inside the snorkel body gasket. The snorkel that I have fitted on my vehicle would be a challenge to remove. If it has been a quick install, then it might just lift away when the bolts are removed.
There will be three holes in the side panel and four holes in the A pillar. I have sealed the Land Rover ducting including the drain valve in the bottom of the air box and the drain in the ducting just rearward of the guard intake. In my case I am pretty confident that it will handle deeper water (not that I plan to get that wet). If the ducting and drain valves have not been replaced/sealed then you are relying on luck. For me, a $350.00 AUD RAI is cheap insurance |
26th Feb 2015 9:20am |
Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 1000 |
Also - just to make sure you are aware: the three holes in the wing will be upto 16mm in size ....
26th Feb 2015 9:31am |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2295 |
Hello capnjapseye
and welcome to Def2Net... your back 'catalog' is impressive and well done at securing a nice looking Defender. I have no hands-on experience regarding your Snorkel, but wanted to make an observation that may or may not be relevant, regarding your plans to fit rear sliding windows. Two Land Rovers back I had a Series III and looked into this. Clearly there are now numerous routes to retro fit sliding (or fixed) glass in a HT... but my understanding is that if the Vehicle was originally sold as a commercial vehicle and the original purchaser claimed back the VAT from HMRC an alteration of the type you plan and its change of vehicle details (both for insurance and the DVLA) would potentially 'reclassify' the vehicle in the eyes of HMRC and the VAT could then need to be paid. This was the case in 1995 when I looked into it. As I said this now might not apply. My Series III had no rear seats so if I had fitted the rear windows this would have been the only change since it left the factory, but the lighter interior, my reason for looking at this wasn't really viable when the full cost (and paper work) was established... it was also part of my justification to get a 300tdi CSW This forum is bound to know more on this but every time I see a HT 'converted' to a 'SW' no one seams to mention this aspect... Good Luck SKIP https://www.defender2.net/forum/topic83242.html |
26th Feb 2015 9:53am |
