Home > Technical > Safari Snorkel Removal
Page 2 of 2 <12
capnjapseye
United Kingdom 2016 Defender 90 Puma 2.2 HT Santorini Black
4wheeler wrote:
The Safari snorkel for that model uses the Land Rover ducting. If it had been installed as per the instructions, sealant should have been used between the snorkel body and the second sealing gasket which fits inside the snorkel body gasket. The snorkel that I have fitted on my vehicle would be a challenge to remove. If it has been a quick install, then it might just lift away when the bolts are removed.
There will be three holes in the side panel and four holes in the A pillar.
I have sealed the Land Rover ducting including the drain valve in the bottom of the air box and the drain in the ducting just rearward of the guard intake. In my case I am pretty confident that it will handle deeper water (not that I plan to get that wet). If the ducting and drain valves have not been replaced/sealed then you are relying on luck.
For me, a $350.00 AUD RAI is cheap insurance Very Happy
Cheers for the continued feedback.
Have now removed snorkel, it was not a big deal other than getting to the top stud/nut inside the wing.
The three holes in the wing I have just plugged with blanking grommets for now and the four holes in the screen pillar, I've just put in 4 stainless screws. I may look at cosmetic improvements later.
I didn't notice any drain valve(s) when I removed the snorkel, should this be obvious?
Anyway, Roy's on his way to pick up the snorkel now for his double cab pickup.
Post #402359 26th Feb 2015 11:34am
Roy5695
United Kingdom 2011 Defender 110 Puma 2.2 XS DCPU Indus Silver
Paul the drain valves. are on the bottom of the pipe work leading to the air box and one in the bottom of the air box itself I believe.
Post #402362 26th Feb 2015 11:43am
capnjapseye
Cheers Roy
All sorted now, I expect you're busy fitting the snorkel to your Defender now
Good luck
Paul
Post #402475 26th Feb 2015 6:13pm
Anderzander
It may sound daft - but would you mind posting a picture up of it removed ?
I'm considering fitting a safari one on mine and I'd like to see what it would leave behind ?
Post #402509 26th Feb 2015 7:34pm
Roy5695
It's not on yet, will be on at the weekend as the missis working all weekend Smile
Thanks again.
Post #402541 26th Feb 2015 8:19pm
capnjapseye
Yer tis:
No cosmetic work done as you can see, three rubber grommets in the mounting holes on the wing and four SS screws in the window pillar.
Post #402686 27th Feb 2015 11:01am
sjwdrew
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Grommet
Hi,
Good job, I'm about to do the same! What size grommets do you need to get? Also where did you get your replacement air grill from?
New to this so any help would be great.
Simon
Post #560222 31st Aug 2016 12:29pm
Page 2 of 2 <12
