Home > Technical > Key remote issues |
sounds like the transponder chip is faulty or not there at all
when you unlock by the button that switches off imobiliser and unlocks doors if you turn off without locking and open door get in , then the chip turns the imobiliser off say sounds like chip is not working or poss its not there on that type of key if you still got a standard fob and key I take it that works ok ? |
22nd Feb 2015 4:00pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20299 |
Have you just tried pressing unlock quickly instead even though it's already unlocked?
22nd Feb 2015 4:35pm |
yes it should be that you can push just unlock without locking first
22nd Feb 2015 5:04pm |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2225 |
Could be the transponder pick up coil around the ignition barrel (presuming it has one to start with)
Steve 02' 110 TD5 Double Cab Rebuild Thread |
22nd Feb 2015 5:06pm |
yep could be the ring , sure a 2012 will have one
really did to test with standard fob , if it all works ring must be working |
22nd Feb 2015 5:09pm |
you need to reset the AS10 Alarm ECU.... IMHO isn't the fob. Have you a Nanocom evo? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
22nd Feb 2015 5:25pm |
SGH Member Since: 27 Sep 2010 Location: Hellingly-Sussex Posts: 1527 |
I will take a look tomorrow tipping it down here now.
Yes it has the coil but that has been moved slightly due to fitting XENG lock shroud but key never worked correctly before coil was moved. No issue with standard key and fob that works just fine. 993 Varioram - Guards Red Defender 2.5 300TDI 110 HCP - Keswick Green Defender 2.2 TDCI 130 HCP - Orkney Grey - GONE Discovery 4 SDV6 HSE LUX - Corris Grey/Black Pack - GONE Discovery 4 SDV6 HSE LUX - Montaciano Red/Black Pack - GONE |
22nd Feb 2015 5:32pm |
Is it doing it all the time or is the immobiliser arming itself first. (Red flash on dash)
22nd Feb 2015 5:41pm |
Steve with the all in one key it only works once to start the car second time it's immobilised so have to lock unlock and then start. 993 Varioram - Guards Red
22nd Feb 2015 5:42pm |
99.9% sure its the chip in the key
has it always done it right from the start with the one piece key? |
22nd Feb 2015 6:00pm |
Yes done it from day 1 993 Varioram - Guards Red
22nd Feb 2015 6:16pm |
sounds like its the wrong key internals for the later alarm units
maybe for the older units as fitted to rover 200's etc , they done same thing , you had to push buttom after imob cut in |
22nd Feb 2015 6:32pm |
I got this from group buy on here quite a while back from dgardel I seem to recall. Mine is a 2.2 I guess I must have been only one to have an issue. 993 Varioram - Guards Red
22nd Feb 2015 6:50pm |
Simon, try a fob re-synch of the 10AS and see if that helps. On the key fob press unlock then lock 4 times within range of the 10AS.
22nd Feb 2015 7:28pm |
