Home > Technical > Key remote issues |
Ah! Now it is clear..... the integrated key DOESN'T work on 2.2 if you have the new PLIP (isn't it?). Only the early 2.2 had the old plip..... 2.2 has the AS10 plus a "new" receiver module for the new blip...... MY07-11 "old" short cable (orange) pin 26 connector C0061 Click image to enlarge MY12-on new receiver module pin 26 and pin 13 connector C0061 Click image to enlarge if you alarm is with "old" plip, try to re-pair (better with the nanocom procedure). I remember that you also bought the POD but it is un-usable now..... let me know... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
23rd Feb 2015 12:17am |
Yes right youuu said, you are using the integrated plip
Have you the possibility to re-pair (or re-learn) the PLIP with the Nanocom? Or, may be, the "range" of the integrated PLIP is smaller than the OEM related to the fact of coil has been moved slightly due to fitting XENG... let me know Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
23rd Feb 2015 9:37am |
