Home > Puma (Tdci) > Advise needed (driveshaft related) |
CapeLandy Member Since: 21 Jul 2008 Location: Cape Town Posts: 558 |
The manual as I copied below, states when fitting back the drive flange to the rear diff you need to add heavy duty locktight to the splines - maybe this is what they are planning to do.
Mine did the same and after they refitted the flange with locktight the clunk was gone. Installation 6 . Remove pinion flange. 7 . Position container to catch oil spillage. 8 . Using a suitable lever, remove and discard pinion oil seal. CAUTION: Take care to avoid damage to oil seal recess. 1 . Clean pinion oil seal recess and pinion flange. 2 . Lubricate NEW oil seal lip with clean oil. 3 . Using LRT-51-010 fit pinion oil seal. 4 . Clean the mating splines of the pinion flange and the differential pinion shaft. 5 . Apply high strength retainer STC50554 to the pinion flange splines. 6 . Instal pinion flange. 7 . Restrain flange using LRT-51-003 and instal bolt. Tighten bolt to 100 Nm (74 lbf.ft). 8 . Position propeller shaft to differential housing and align reference marks. |
9th Jun 2010 8:11am |
o4dn Member Since: 08 Jan 2010 Location: South West Posts: 549 |
Thanks CapeLandy!
9th Jun 2010 3:30pm |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 |
Same here as Cape... locktight worked NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
9th Jun 2010 5:46pm |
sav07 Member Since: 12 Apr 2009 Location: Newcastle Posts: 7 |
I have spoken to the dealer multiple times about this as I am having the same issue, and I am thinking about completing this procedure myself. Do I have to drain oil from the rear diff; if do not remove the pinion oil seal? If it is not drained how much oil should come out through the pinion oil seal? Thanks for your time.
Regards Sav |
5th Jan 2011 1:04am |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2448 |
Are you sure the clunk comes from the rear? When the clutch is "done" you get a clunk "transmitted" along the driveline. If you take the shafts away, then you need to lock the Tbox and that will cause another clunk as a dog clutch is then engaged. Puma 110" SW ............................................................. Earth first. Other planets later |
5th Jan 2011 1:54am |
Sorry I should have posted a follow-up...
It turned out to be faulty rear diff, and it got replaced under warranty and is all sorted now (it's whining on deceleration now, but I can definitely live with this as it's been said here that it's normal). So all is well now, I love my Puma |
5th Jan 2011 7:52am |
The whining will be "in creccendo" so I suggest you to make them to adjust the pinion/crown asap. Puma 110" SW
5th Jan 2011 10:12am |
Is the whining a defect in the diff? Is the diff to wear out faster? Or is it just a noise... |
5th Jan 2011 10:23am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8155 |
if a diff is correctly built is should whine at all.
you dont need to drop the diff oil to do this. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
5th Jan 2011 4:47pm |
