Home > Maintenance & Modifications > Long range tanks
Page 3 of 3 <123
borderterrier
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
walfy wrote:
A nice T55. Where is that?
T54/55 Wink
Post #266889 15th Sep 2013 12:56pm
walfy
Is there much difference between them? My tell tells were the space between roadwheels 1 + 2, and the handles on the turret side and something abot the front armour as well but not sure what 110 D250 SE HT
110 USW SOLD
Polaris RZR 900XP SOLD
Post #266893 15th Sep 2013 1:08pm
borderterrier
Just the uncertainty regarding in which year it was first seen.
Post #266894 15th Sep 2013 1:10pm
walfy
So I was correct Thumbs Up
You were being a tank geek Rolling with laughter Rolling with laughter 110 D250 SE HT
110 USW SOLD
Post #266895 15th Sep 2013 1:11pm
walfy
jst wrote:
yes i did, Brendan supplied one, 45L side tank in the end. easy to fit and fills off the main filler and that fills the main tank.
105/110L tank now, i loose a bit as i didnt fit a balance pipe, too vulnerable in my opinion
Had a look at his site but nothing showing. Will keep the search going 110 D250 SE HT
110 USW SOLD
Post #266896 15th Sep 2013 1:13pm
@ JST or anyone that knows....
What exactly does the balance pipe do? I've got a tank here which, after some repairs, will be fitted, and it needs said balance pipe.
What would happen if one were leave the pipe out? I would have thought that after xx miles driving the fuel would eventually splash down into the main tank if there was a vacuum effect?
Post #266898 15th Sep 2013 1:26pm
walfy
Wouldn't of thought there would be a vacuum effect. Surely it would breath through the filler cap if needed. It would just gravity feed.
Also why does the balance pipe need to be fitted to the bottom of the main tank rather than in the top? 110 D250 SE HT
110 USW SOLD
Post #266900 15th Sep 2013 1:28pm
Cakey
United Kingdom 2012 Defender 90 Puma 2.2 XS CSW Santorini Black
Someone knows their tanks , t55 handles on the turret .
Post #266986 15th Sep 2013 6:14pm
davew
The balance pipe simply joins the bottoms of the two tanks together, balancing the fuel level between the tanks and ensuring that as much of the fuel as possible is drained from the auxiliary tank. Normally the pipe will be as low as practicable on the aux tank and an inch or so above the bottom of the main tank. Gravity will ensure that the fuel drains form the aux tank into the main tank.
Without the pipe any fuel below the main pipe in the auxiliary tank would not be useable. There is no vacuum effect, even if the tanks are below atmospheric pressure they will both be at the same pressure. Any "splash effect" can work both ways. http://www.yorkshireoffroadclub.net/
Post #266992 15th Sep 2013 6:27pm
Ahh, I get it. The balance pipe makes sure that the last little bit of fuel can drain out of the aux tank instead of sitting below the main through-flow pipe.
Post #267018 15th Sep 2013 7:36pm
walfy
Thinking about the balance pipe, it does seem to be a bit exposed and what do you gain by fitting it? 5-10L. I think I'd rather have peace of mind and lose 5L of capacity. 110 D250 SE HT
110 USW SOLD
Post #267104 16th Sep 2013 5:54am
leeds
Yes the complete range of items we can supply are not on our website. Barbara still has another job! Razz
One of our problems is the vast range of fuel tanks we can supply from the plastic wing tanks for 90's to wing tanks for 110 in ali, mild steel, stainless steel, double bottomed or just a single skin bottom, the Puma's are a different shape to those of earlier Defender models. Then there are larger main tanks, 3 materials and two different bottoms, Then there are sill tanks.
Drop us an email/pm with your requirement and vehicle and I will try and sort something out for people.
As for the balance pipe and it being vunerable, we have not found it to be a problem. Have had a wing tank and balance pipe fitted to our red 110 for at least 8 years. In that 8 years have been to many countries, on and off tarmac, setting out and competing in trials, and being in remote places. Have not damaged the balance pipe, nor had any real concerns about the balance pipe. IF I had serious concerns about the balance pipe I would have either protected it or removed it. However I have not done either.
Brendan
Post #267567 17th Sep 2013 10:37pm
leeds
Sorry hit the back button. Must stop that habit Whistle
Brendan
Post #267568 17th Sep 2013 10:37pm
jst
Jamie - yep - your last post is right.
Walfy - it needs to go to the bottom part of the main tank as the aux tanks bottom is also quite low and you need gravity flow.
if you had a larger main tank you would have more of the main tank exposed at the bottom so lots of mounting options for the balance pipe.
with a std main tank options are limited as it sits well between the chassis rails so alot of the bottom part of the tank is covered up.
I also have a southdown rear tank guard which limits it even further, hence didnt fit it. i lose 5L or so, some splashes down the main filler cornering etc anyway. i use it as a reserve as it could always be syphoned out and fed into main tank with a funnel. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #268702 23rd Sep 2013 7:45am
Page 3 of 3 <123
