Home > Maintenance & Modifications > Long range tanks
Page 1 of 3 123>
jst
Long range tanks
Anyone added a long range tank to their 110? if so which ones and what did you consider?
i am considering one that goes in the rear wheel arch and uses the same std filler and then feeds into the main tank.
any suggestions on suppliers? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #33920 8th Jun 2010 10:20am
Glynparry25
I have looked around and am going to go for a wheel arch one- the one I like the most ois from Devon4x4, but as usual it is a little more expensive than some others. From what I remember it is stainless steel, and has a 46l capacity
Glyn Sheep
Post #33937 8th Jun 2010 1:00pm
K9F
Ear tiz....5 pence short of £466 inc VAT
http://www.devon4x4.com/products_a/p1708c2...-tank.html If you go through life with your head in the sand....all people will see is an ar5e!!
Post #33939 8th Jun 2010 1:13pm
Glynparry25
Thanks for that Mal ^^^^that is the one I am talking aboot^^^^^^^^^
Glyn Sheep
Post #33940 8th Jun 2010 1:16pm
K9F
Not a bad concept, one would assume it acts like a header tank and just keeps the main tank filled???? Only draw back I can see is that it may be that you only know exactly how much fuel you have when the needle starts to drop.
I may be wrong though if it is plumbed in in a cross-feed manner like the old Discovery tanks. Question
If I was still in BFG it would be money well spent if you come back often!
Sure someone will know for sure! Dog Thumbs Up Dog If you go through life with your head in the sand....all people will see is an ar5e!!
Post #33942 8th Jun 2010 1:23pm
Glynparry25
It is as you say above, because it sits above the main tank your needle won't move until you hit about 80 litres, Can be counteracted by fitting a secondary float in the aux tank to another gauge.
Worked it out....13 fills pre-leaving Germany and it pays for itself.....but also means an extra 2 jerry cans before going on the ferry..... so technically about 8-10 fills...... plus the thought of going 600miles without filling!!
Roll on November and 45p a litre fuel Very HappyVery HappyVery HappyVery HappyVery HappyVery Happy
Glyn Sheep
Post #33948 8th Jun 2010 2:35pm
leeds
Be careful with wing tanks and year of defender plus size of tyres!
Land Rover does subtle changes which can cause problems.
We have a 48 litre mild steel one fitted to our 96 110 which runs on 255/85/R16. On full articulation upwards the tyre/mud stuck in tyre just rubs the wing tank. There is no tank guard for wing tanks so I got mine made with a double bottom.
On our 09 110 Ute we got a stainless wing tank with a double bottom. This 110 also runs on 255/85/R16. We noticed that there would be a problem on full articulation in that the tyres would catch on the tank. Luckily the manufacturers are local and have now modified the wing tank for 09 models. This will be going on later this week hopefully. We also have a 110 litre main tank on the Ute. So will have about 160 litre capacity which should give us a range of up to 1,000 miles on tarmac. Off tarmac that could be down to 500-600 miles
The wing tank works by gravity feeding directly into main tank so no pumps. A balance pipe drains the bottom of the tank.
Cost for a mild steel tank would be £250 + VAT. Stainless would be £285 + VAT (say £335 round numbers) OK carriage is extra! Razz Say £20
HTH
Brendan
Post #33969 8th Jun 2010 6:02pm
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
Why not a standard 90 pre td5 tank under the driver seat? I don't know how it fits in a 110. I will fit the old tank to my 90 td5 too. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #33970 8th Jun 2010 6:10pm
leeds
For a 110 that would require some form of pump/crossover valve
A couple of photos. Old main tank, new 110 litre stainless tank
Stainless wing tank
HTH
Brendan
Post #33972 8th Jun 2010 6:31pm
jst
i dont really want to go to the hassle of fitting a tdi 90 tank as i would have to move the ABS wiring/ecu thing etc and i would like to keep it as a simple bolt on off as possible.
Leeds - that larger 110 std position tank i take it that it gains its cpacity in depth so does it protrude further down than the std one or is the capacity gained by going up only?
With respect to the wing tanks are those the prices from you in that you can supply them? and can you do the ones for Pumas with the mod you suggest at the same price? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #33987 8th Jun 2010 9:12pm
leeds
James,
The only photo I have got is this
Yes it goes down as well as up and into all the corners. The rear anti roll bar mounts are lowered.
Don't believe it alters the departure angle. If you like will try and take some more photos but that can't be for a day or two.
The standard Land Rover tow bracket will not fit with this big tank. You will have to consider a rear 2" receiver if you wish to tow.
Yes we can supply them. If you want a good look at the tanks come and have a good poke around our vehicles at Billing.
The price I quoted was for the standard wing tank. Can't see the modification for 09 models onwards altering the price. Double bottom would be an extra cost. Not sure how much but can check. If you are interested pm your requirements and vehicle details and I will check price and availability/delivery.
HTH
Brendan
Post #33994 8th Jun 2010 9:42pm
jst
Leeds - PM sent Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #33995 8th Jun 2010 9:48pm
roel
I moved the ECU higher up inside anyway to prevent water problems. I have both tanks so I just need a pump.
You could build in the tanks that Leeds showed and do the 90 tank so you have even more diesel with you. Roel
Post #34071 9th Jun 2010 7:06pm
leeds
Well if you want to go to extreme you could fit
Replacement main tank 120 litres
Wing Tank 48 litres
RHS Pod Tank 66 litres
LHS Pod Tank 56 litres
Makes 290 litres Lets just say I would not want to fill that lot up to often Razz
Would give a range of about 1,800 miles though Razz
Brendan
Post #34076 9th Jun 2010 7:42pm
jst
290 would be a bit OTT for me!!!
the wing tank would suffice for what i need it for without impacting underneath clearence. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #34098 10th Jun 2010 8:21am
Page 1 of 3 123>
