![]() | Home > Events > Goodbye wave to the old Defender...? |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2303 ![]() ![]() ![]() |
Hello strang
I can't answer your question about access onto wwwDefenderTribute.com but if your registered then zone30 will see you and will probably be able to help you sort this out. Can I suggest, if you want to join in, that you just register also on here... http://www.defender2.net/forum/topic38551.html This allows you to see who from D2N is going. ![]() https://www.defender2.net/forum/topic83242.html |
