Home > Puma (Tdci) > Loose wheel? |
running in is to put a fine polish surface on , there is no real difference between a tapered roller brg or any other brg its still two surfaces (roller/ball and track) against each other
if you looked at a brg surface under a microscope it would look like a ploughed field , running in is what it says to get the two surfaces polished to each other and for longest possible life I know grinding / finishing processes are a lot better than they used to be , BUT I would not fit a new brg in anything then use to maxium load and speed until it had settled in and been run a while allowing grease to spread out etc I would take it steady for a while , check temp of hub etc , in other words run it in a bit and if your not happy take it back !!! or just take it back anyway for peace of mind and safety for you you would be amazed at the amount of garages that don't test drive cars before they go out !!! Last edited by munch90 on 10th Jan 2015 8:23pm. Edited 1 time in total |
10th Jan 2015 11:06am |
zone30 Member Since: 07 Sep 2012 Location: Gent Posts: 669 |
It's going back.
If they say all is fine and things go bad, at least ir's on record. |
10th Jan 2015 11:39am |
