Home > Puma (Tdci) > Loose wheel?
Page 2 of 2 <12
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
I have never known of a roller bearing having to be run in. It sound as mention above it has either not been shimmed properly, incorrectly fitted or even put in dry. Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #386962 10th Jan 2015 10:51am
munch90
running in is to put a fine polish surface on , there is no real difference between a tapered roller brg or any other brg its still two surfaces (roller/ball and track) against each other
if you looked at a brg surface under a microscope it would look like a ploughed field , running in is what it says to get the two surfaces polished to each other and for longest possible life
I know grinding / finishing processes are a lot better than they used to be , BUT I would not fit a new brg in anything then use to maxium load and speed until it had settled in and been run a while allowing grease to spread out etc
I would take it steady for a while , check temp of hub etc , in other words run it in a bit
and if your not happy take it back !!!
or just take it back anyway for peace of mind and safety for you
you would be amazed at the amount of garages that don't test drive cars before they go out !!!
Post #386969 10th Jan 2015 11:06am
zone30
Belgium 2011 Defender 110 Puma 2.4 X-Tech LE Nara Bronze
It's going back.
If they say all is fine and things go bad, at least ir's on record.
Post #386982 10th Jan 2015 11:39am
Page 2 of 2 <12
