Home > Td5 > No hazards or indicators
gavinpm
England 2006 Defender 90 Td5 SW Cairns Blue
Thought this was going to be simple but I can't (easily) locate the indicator relay.
Any advice please - it's an 06 90
Thanks
Gavin
Post #385560 6th Jan 2015 7:03pm
Is the connector / plug on the rear of the hazard switch securely connected?
Post #385562 6th Jan 2015 7:04pm
gavinpm
Didn't even think of that Steve - is that a likely cause ?
Does the hazard switch just unclip,or is there a knack to it ?
Thanks
Post #385565 6th Jan 2015 7:07pm
alwoodley72
England 2008 Defender 130 Puma 2.4 HCPU Alaska White
If it isn't that, think the relay is in the dash behind dials, only a few screws to get binnacle off...! Mine went on my 04 dc and it was there...
Cheers. Alex
Post #385593 6th Jan 2015 7:51pm
alwoodley72
Cheers. Alex
Post #385594 6th Jan 2015 7:52pm
I know that on the Puma if the hazard light switch is removed the indicators won't work or the hazards obviously.
This is why I mention that maybe it's loose or not fully connected.
It in-clips from behind by two metal tangs, I'd have thought the TD5 wouldn't be too much different.
Failing this it might well be the relay.
Post #385611 6th Jan 2015 8:18pm
gavinpm
Thanks Steve and Alex - job for tomorrow.
Gavin
Post #385613 6th Jan 2015 8:22pm
gavinpm
How on earth do you remove the central switch panel - obviously the two screws under the panel but how is the top connected to the underside of the dash ?
Thanks
Gavin
Post #386353 8th Jan 2015 3:56pm
Paddie42
England 2003 Defender 110 Td5 SW Belize Green
There are 3 screws that hold it in place under the Dash. You have to either remove the dash, or loosen it enough to see them.
the 3 screws only need to be undone slightly and then it will slip out.
Post #386357 8th Jan 2015 4:05pm
gavinpm
Censored .
Thanks Paddie - I was hoping it wouldn't involve the dash.
Sorry for my ignorance but where are those 3 screws located.
Thanks again
Gavin
Post #386363 8th Jan 2015 4:12pm
Paddie42
Just been looking on the wibbly wobbly web and found this;
http://www.reedx.net/landrover/mods/2002da...e_diag.gif
You can see (hopefully) three lugs on the console. That is where the screws are
Hope this helps.
Post #386368 8th Jan 2015 4:26pm
gavinpm
Great.
Thanks very much Paddie, been searching for such a diagram myself without success.
Post #386375 8th Jan 2015 4:49pm
