Home > Td5 > No hazards or indicators |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20474 |
Is the connector / plug on the rear of the hazard switch securely connected?
6th Jan 2015 7:04pm |
gavinpm Member Since: 19 Oct 2012 Location: Wiltshire Posts: 117 |
Didn't even think of that Steve - is that a likely cause ?
Does the hazard switch just unclip,or is there a knack to it ? Thanks |
6th Jan 2015 7:07pm |
alwoodley72 Member Since: 14 Mar 2010 Location: salisbury, wilts Posts: 724 |
If it isn't that, think the relay is in the dash behind dials, only a few screws to get binnacle off...! Mine went on my 04 dc and it was there...
Cheers. Alex |
6th Jan 2015 7:51pm |
Cheers. Alex |
6th Jan 2015 7:52pm |
I know that on the Puma if the hazard light switch is removed the indicators won't work or the hazards obviously.
This is why I mention that maybe it's loose or not fully connected. It in-clips from behind by two metal tangs, I'd have thought the TD5 wouldn't be too much different. Failing this it might well be the relay. |
6th Jan 2015 8:18pm |
Thanks Steve and Alex - job for tomorrow.
Gavin |
6th Jan 2015 8:22pm |
How on earth do you remove the central switch panel - obviously the two screws under the panel but how is the top connected to the underside of the dash ?
Thanks Gavin |
8th Jan 2015 3:56pm |
Paddie42 Member Since: 24 Apr 2014 Location: Hamphire Posts: 230 |
There are 3 screws that hold it in place under the Dash. You have to either remove the dash, or loosen it enough to see them.
the 3 screws only need to be undone slightly and then it will slip out. |
8th Jan 2015 4:05pm |
Thanks Paddie - I was hoping it wouldn't involve the dash. Sorry for my ignorance but where are those 3 screws located. Thanks again Gavin |
8th Jan 2015 4:12pm |
Just been looking on the wibbly wobbly web and found this;
http://www.reedx.net/landrover/mods/2002da...e_diag.gif You can see (hopefully) three lugs on the console. That is where the screws are Hope this helps. |
8th Jan 2015 4:26pm |
Great.
Thanks very much Paddie, been searching for such a diagram myself without success. |
8th Jan 2015 4:49pm |
