![]() | Home > Puma (Tdci) > Loss of accelerator pedal response 2.4 Puma |
Regis974 Member Since: 09 Apr 2016 Location: Peru Posts: 1 ![]() |
Hello! just wanted to know if you solved the problem? and how? please tell me you did and you already know what the problema was
Mogboy Member Since: 21 May 2013 Location: Brisbane Posts: 31 ![]() ![]() ![]() |
Well I did replace the clutch sensor and that seemed to fix things.
I do feel however that it's more relayed to the clutch fluid going black and sludge collecting inside the sensor oriface. Recently, it has started to play up again. Disconnecting the sensor wires seems to get rid of it. I've run it for 2 weeks like that, and all good. This time I will just clean the sensor and flush the clutch hydraulics. Hope to do that in the next week. Cheers Mogboy |
