Home > Puma (Tdci) > Loss of accelerator pedal response 2.4 Puma
Page 2 of 2 <12
Mogboy
Australia 2007 Defender 110 Puma 2.4 SW Belize Green
A little more information has emerged...
In the last few days during gear changes, the revs increased, as if I was late backing off on the accelerator. Not every change, but a few isolated ones. It happened a bit more this morning, and I know suspect the clutch sensor switch might be sticking.
It's purpose is to reduce the engine torque for the clutch re-engagement, when shifting gears. Chances are it may have been sticking at reduced torque position, after a gear shift before, causing loss of throttle response.
Anyway, I'm ordering a new clutch sensor, and see what happens.
Mogboy
Post #439012 19th Jul 2015 11:58pm
Regis974
Hello! just wanted to know if you solved the problem? and how? please tell me you did and you already know what the problema was Sad
Post #522369 9th Apr 2016 12:29am
Mogboy
Well I did replace the clutch sensor and that seemed to fix things.
I do feel however that it's more relayed to the clutch fluid going black and sludge collecting inside the sensor oriface.
Recently, it has started to play up again. Disconnecting the sensor wires seems to get rid of it. I've run it for 2 weeks like that, and all good. This time I will just clean the sensor and flush the clutch hydraulics. Hope to do that in the next week.
Mogboy
Post #522408 9th Apr 2016 8:50am
Page 2 of 2 <12
