Home > Puma (Tdci) > Loss of accelerator pedal response 2.4 Puma
Mogboy
Australia 2007 Defender 110 Puma 2.4 SW Belize Green
My 2007 Puma (265,000 kms) will occasionally lose all response from the accelerator pedal. It's an intermittent problem, so difficult to demonstrate to someone. Here's a description...
Intermittent and most of the time doesn't happen
No engine malfunction light
No fault codes on scan gauge
Engine at operating temperature
Usually throttle response completely lost after changing to a higher gear
Can also be a problem changing to a lower gear under load (eg up hill)
Usually overcome after tickling accelerator pedal back and forth, but likely to play up on each successive gear change
One way I have been able to avoid the problem, is not dropping revs between gear shifts
If I shut down the engine for 5-10 minutes, the problem disappears
It may not malfunction for several days or longer. It disappeared for over 12 months after the first series of issues
I've checked connections to the accelerator pedal, turbo, etc, and they appear fine. Anyone have this experience before?
Mogboy
Post #385367 6th Jan 2015 1:09am
Cheshire110
Maybe completely barking up the wrong tree but just maybe worth checking the fuel filter?
In the past my 110 and dads toyota land cruiser have both had odd issues relating to hills, throttle response and loss of power after picking up a bad batch of diesel and blocking out fuel filters. The same could presumably happen over time if not changed.
An outside chance but maybe worth excluding anyway. And probably worth keeping filter changed every 1-2 years anyway if you haven't. Cheers, David
Post #385369 6th Jan 2015 1:18am
Mogboy
Thanks David
I have recently changed out the fuel filter, so pretty sure it's not that. Different sort of response to most fuel filter blockages I've experienced, but worth the suggestion anyway.
Post #385373 6th Jan 2015 3:20am
It is just conceivable that the Volume Control Valve on the fuel pump is sticking and causing fueling issues. Generally when this happens there won't be any fault codes generated, and the diagnosis is really that there aren't any other obvious faults. There's also no way to test it without simply replacing it and seeing if it makes a difference. It is particularly common if you have had any fuel contamination at any time.
Over the years I have had a number of wierd misfiring/loss of power/uneven running issues from VCVs, they are also famous for needing replacement on Transits. Generally the symptoms are similar to those you may get from a malfunctioning EGR valve except without any DTCs beiong generated.
Post #385397 6th Jan 2015 9:57am
Eduardo
Mogboy,
Maybe is the same issue that happens to you
There are several experiences in this forum with the problem of "loss of power" and you will find several threads with information.
In short: Main problem is the cooling system of the Defender that is quite adjusted and sometimes cannot cope with hot climates. When the coolant temperature rise over certain point triggers the engine protection reducing the revs to protect it despite you are trying to acelerate it. In general there is a coincidence between a gear change and the appearance of the problem.
The Temp gauge in general not shown the temp rising. Also No MIL ligth on. After several seconds the temps goes down and the engine works again without any trouble.
I hope that can help
Cheers from Chile Eduardo
Post #385457 6th Jan 2015 2:11pm
Lorryman100
Remove the plug from the TPS (Throttle Position Sensor) and coat the connections in electrical contact cleaner and plug back in. If you have a nanocom check the D and E values on the TPS at 2000 rpm and post the recorded values on here.
From the description of the fault and your actions to overcome, the TPS is the first thing I would look at. :thumbsup:
Post #385475 6th Jan 2015 3:31pm
Mogboy
Thanks lorryman.
Just have a scan gauge...not manikin, but will get s check readings when I get a chance to drop in. In the mean time I'll remove accelerator to clean contracts more thoroughly than I have by just wriggling connector to get a better contact.
Cheers for everyones help.
Mogboy
Post #386197 8th Jan 2015 6:40am
earthscapes
Hi.
Would like to know if you sorted this problem.
I am just having the same issues?
Post #435974 5th Jul 2015 7:51pm
Mogboy
Just by cleaning the contacts, I have had long periods without issues (several months), leading me to think it was the pedal assembly. I replaced it a couple of weeks ago and am currently evaluating things. I'm not sure if it has been the answer, as I felt a couple of dull responses going up hill after about 25 minutes running.
I'll keep monitoring it, and if it hasn't fixed it, the next suspect is probably the VCV I guess.
Post #436031 6th Jul 2015 3:51am
Mogboy
The intermittent problem remains after replacing the accelerator pedal assembly. The engine goes really well with excellent power, but when it plays up, it's only when its warmed up and at lower revs and throttle settings. Today it experimented at 2 opportunities by depressing the clutch while keeping the throttle steady when playing up. On both occasions the revs picked up as per normal.
I was going to investigate the VCV next, but this now makes me wonder if there might be a sensor for the turbo playing up. I have confirmed that the wires to the turbo are intact before, and it's quite obvious that the turbo itself is fine. Also plenty of fuel available to make good power most of the time.
Anyone got suggestions?
Mogboy
Post #437344 13th Jul 2015 1:58am
Caterham
not wanting to send you 'off course' but perhaps a little food for thought and welcome for others dismiss this but a couple of things that may be worthy of consideration;
hi/lo selector has impact on accel pedal response - could this be the route of your problems?
also clutch switch does things to the engine controls - is your clutch pedal motion ok - could something be sticking / not working correctly? Also this links into the wiring at the rear ie brake lights?
does the engine continue to sound right? when mines is running fine the intake has a lovely buzzing sound - when it's not it sounds more like a clatter - to me it's as if the turbo not up to speed and hence the clatter and lack of response?
whatever - good luck and please keep us all posted?
one last thing....are you happy the clutch is fully disengaging / working fine?
Post #437371 13th Jul 2015 9:15am
Mogboy
Hi Caterham
Thanks for those thoughts. The clutch is engaging & disengaging normally, and I have cleaned the electrical connections to the clutch master cylinder as a matter of course. I don't get any clatter from the engine. It sounds nice & quiet really.
Post #437570 13th Jul 2015 11:22pm
Gonarezhou
South Africa 2015 Defender 110 Puma 2.2 SW Alaska White
Sounds like a "psycho" ECU to me. It will be interesting to see what it finally resolves the problem.
Post #437580 14th Jul 2015 6:23am
Mogboy
Had certainly crossed my mind too, Gonarezhou
Post #437582 14th Jul 2015 6:29am
Caterham
another wild though here......
as has been well documented on here a high temp can put the engine in to a reduced power mode.
I've wondered but never followed it up. is it purely the water temp that will cause this? the reason I ask is the wire to the (I presume) oil temp sensor seems knackered / stiff on mine and it lead me to wonder what it actually does - presumably something, could it also have an impact similar to the water temp?
If not then what's it for?
(I'm referring to the sensor which from memory is somewhere near the oil filter)
Post #437591 14th Jul 2015 7:24am
