Home > Td5 > Turbocharger wastegate short circuit CURRENT |
Guessing the code could be for the electric vaccum control valve that controls vacuum to the wastegate diaphragm, what it means sorry not a clue !
31st Dec 2014 6:22pm |
df1 Member Since: 06 Aug 2011 Location: Ireland Posts: 221 |
I thought the diaphragm was just controlled by a pipe from the induction pipe just before the inter cooler ?
31st Dec 2014 7:50pm |
Not really had much to do with td5 , but looks like they have something like this
eBay Item No. 321076065397 |
31st Dec 2014 8:05pm |
Think they are disco only.
31st Dec 2014 8:28pm |
AFAIK td5 disco's wastegates are ECU controlled but Defenders are not. Roel
31st Dec 2014 8:29pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6093 |
^^^^ +1
Discoveries are ECu controlled, defenders are mechanical, so there's no "error" code that can occur from them. |
31st Dec 2014 10:32pm |
Is it possible that the error code is generated because of over or under boost pressure in manifold then ?
Maybe the pressure sensor in inlet manifold faulty ? |
1st Jan 2015 7:47am |
Can you clear the fault and see if it comes back? That's what I do with my D3. If it comes back quickly I will look further otherwise it's just one off the things.
I think over boost will have it's own faultcode, under boost I don't know. The td5 will go to limp mode if to high manifold pressure is measured. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
1st Jan 2015 8:50am |
achuakh Member Since: 12 Apr 2012 Location: Singapore Posts: 158 |
If it is over boost, it will log as "turbo charger over boost"
From what it seems, there might be a wiring issue. Clear the faults first and then see if it comes up again. From the land of the most expensive land rover defenders on planet earth. At �125k for a XS 110 csw and you get to own it only for 10yrs! Please find me a good reason to stay on this island. |
3rd Jan 2015 3:08pm |
Cleared the fault 2 days ago and hasn't come back.
Still a bit puzzled how I had the blue smoke then just clear. Hasn't reappeared either. Beginning to think it's something with the injector loom. |
3rd Jan 2015 7:59pm |
Is there oil in the red connector at the ecu? Roel
4th Jan 2015 2:38pm |
Red plug completely clear.
6th Jan 2015 8:15am |
Then you probably not have a injector oil loom problem. Roel
6th Jan 2015 3:30pm |
