Home > Technical > Terrafirma TF930 Land Rover Diagnostic Tool
SupraAyf
United Kingdom 2011 Defender 90 Puma 2.4 HT Orkney Grey
Hi guys,
Does anyone have any experience with the new Terrafirma TF930 diagnostic tool. It seems like a good deal at £100 with P&P included.
Here's a link:
http://www.ebay.co.uk/itm/Terrafirma-Handh...2a4906cc78
Cheers,
Andrew - Andrew -
Post #383640 31st Dec 2014 3:51pm
jimbob7
On the more expensive diagnostic tools you can activate or test systems like abs pump,something you might want to consider IF this tool doesn't do that,I notice it does test some things,but I only recognise "canbus" .Need more info tbh. Pov.spec,ftw. 2006, 110,TD5.
Post #383656 31st Dec 2014 4:22pm
SupraAyf
Thanks Jim, I may just take a punt and report back on its performance. The idea of identifying the DTCs appeals to me - and for 100 quid only. It's my birthday soon so I'll drop a wink to the boss Smile - Andrew -
Post #383662 31st Dec 2014 4:39pm
SupraAyf
I've ordered one so it should be here on the 6th Jan.
I don't think I can go wrong for £100, all inclusive? - Andrew -
Post #384755 4th Jan 2015 11:54am
SupraAyf
Right guys, it arrived today and I was straight in the box. Everything is so easy to use and the navigation menu is so simple that it could easily be used by a 6-year old.
You can choose up to 5 different data streams to view on the screen, right from engine temps to MAF readings etc
The system takes about 10-seconds to run a full diagnostic check while the option to remove DT codes takes all of a few seconds too.
The screen is 2.8 inches wide and shows the DTC numerical reading plus the actual subject which it relates to - very handy.
It is not able to programme anything but for 100 quid!!!
This has to be the best thing I've bought for years.
Very happy. - Andrew -
Post #385669 6th Jan 2015 10:14pm
Stue5
Italy 2005 Defender 110 Td5 USW Alpine White
Glad you're happy with it Thumbs Up
Do you know anyone with a td5 defender you could try it out on?
Just curious to know Thumbs Up
http://www.defender2.net/forum/topic33825.html Range Rover p38 4.6 99 lpg(gone Sad )
Post #385676 6th Jan 2015 10:26pm
bob neville
Sounds interesting. Can it reset the service indicator on 2.2's ?
2013 Defender 90 CSW - sold
Post #385697 6th Jan 2015 10:44pm
SupraAyf
Hi Stu,
Yes, I've just checked the menu and it does support a Diesel TD5. The actual diagnostic choices are:
1997 and beyond: MS4 Engine / TD5 Diesel.
2007 - 2010: Diesel I4 (2.4L)
2011: Diesel 2.4L
2012: Diesel 2.2L
All the best,
Andrew - Andrew -
Post #385879 7th Jan 2015 12:06pm
SupraAyf
Bob
Not sure Bob but I could send an email to the service support center (provided with the package) and see what they say.
Cheers,
Andrew - Andrew -
Post #385880 7th Jan 2015 12:07pm
bob neville
Be great if you could Andrew Thumbs Up
If it does then it means I can have a code reader for the TD5 and Tdci and clear the service indicator on my remapped 2.2 ECU.
Failing that my friendly Indie said he would clear the indicator for me.
Post #385927 7th Jan 2015 2:28pm
SupraAyf
Hi Bob,
I have just sent an email to Barnett Davies who is the TF930 technical guy in the US. I'll drop you a note when I receive a reply.
All the best,
Andrew - Andrew -
Post #385965 7th Jan 2015 4:03pm
bob neville
Thanks Andrew - much appreciated Thumbs Up
Post #386043 7th Jan 2015 7:41pm
Stue5
Thank you very much for having a look Andrew Bow down (now I know Thumbs Up )
Now what else can I put on my order two make the most of the 30kg p&p Whistle ( Big Cry I made a order last week) Range Rover p38 4.6 99 lpg(gone Sad )
Post #386150 7th Jan 2015 11:30pm
SupraAyf
Stu, you're very welcome sir and best of luck with the 29 other kg's that you need to make up Smile
Bob: This is the reply from the US -
Dear Andrew,
Thank you very much for your email.
And very nice to know that you like our Landrover scanner.
However, I'm afraid our i930 Landrover scanner can not reset the service indicator on a Land Rover Defender 2012 TDCii .
Sorry about that.
Thank you very much for your support.
Have a nice day.
 - Andrew -
Post #386240 8th Jan 2015 11:22am
Skeggy 90
England 2011 Defender 130 Puma 2.4 SW Bali Blue
Had my one delivered today, it is a great little machine, works a treat on my Puma and my L322
Pics below, it does ABS but only from the TD5 menu, this is quite common with other code readers I have used previously. Best thing about it is that it is unlocked and without license, so if you have more than one vehicle it is an even bigger bargain.
 90 300 TDI SW (sold)
130 TD5 Utility (Foley SV) (sold)
110 TD5 Hardtop (sold)
110 TDCI Utility (sold)
1st Edition Range Rover Sport Supercharged
Velar P380 HSE
Discovery 1 V8 auto
Puma 130 Double Cab (sold)
R35 GTR
Defender 110 300 TDI CSW (sold)
2010 110 XS Utility
Post #386284 8th Jan 2015 1:49pm
