Home > Technical > Terrafirma TF930 Land Rover Diagnostic Tool |
SupraAyf Member Since: 08 Sep 2014 Location: Durham Posts: 142 |
Hi guys,
Does anyone have any experience with the new Terrafirma TF930 diagnostic tool. It seems like a good deal at £100 with P&P included. Here's a link: http://www.ebay.co.uk/itm/Terrafirma-Handh...2a4906cc78 Cheers, Andrew - Andrew - |
31st Dec 2014 2:51pm |
Thanks Jim, I may just take a punt and report back on its performance. The idea of identifying the DTCs appeals to me - and for 100 quid only. It's my birthday soon so I'll drop a wink to the boss - Andrew -
31st Dec 2014 3:39pm |
I've ordered one so it should be here on the 6th Jan.
I don't think I can go wrong for £100, all inclusive? - Andrew - |
4th Jan 2015 10:54am |
Right guys, it arrived today and I was straight in the box. Everything is so easy to use and the navigation menu is so simple that it could easily be used by a 6-year old.
You can choose up to 5 different data streams to view on the screen, right from engine temps to MAF readings etc The system takes about 10-seconds to run a full diagnostic check while the option to remove DT codes takes all of a few seconds too. The screen is 2.8 inches wide and shows the DTC numerical reading plus the actual subject which it relates to - very handy. It is not able to programme anything but for 100 quid!!! This has to be the best thing I've bought for years. Very happy. - Andrew - |
6th Jan 2015 9:14pm |
Stue5 Member Since: 06 Jul 2014 Location: Marche Posts: 111 |
Glad you're happy with it
Do you know anyone with a td5 defender you could try it out on? Just curious to know http://www.defender2.net/forum/topic33825.html Range Rover p38 4.6 99 lpg(gone ) |
6th Jan 2015 9:26pm |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248 |
Sounds interesting. Can it reset the service indicator on 2.2's ?
Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
6th Jan 2015 9:44pm |
Hi Stu, Yes, I've just checked the menu and it does support a Diesel TD5. The actual diagnostic choices are: 1997 and beyond: MS4 Engine / TD5 Diesel. 2007 - 2010: Diesel I4 (2.4L) 2011: Diesel 2.4L 2012: Diesel 2.2L All the best, Andrew - Andrew - |
7th Jan 2015 11:06am |
Not sure Bob but I could send an email to the service support center (provided with the package) and see what they say. Cheers, Andrew - Andrew - |
7th Jan 2015 11:07am |
Be great if you could Andrew
If it does then it means I can have a code reader for the TD5 and Tdci and clear the service indicator on my remapped 2.2 ECU. Failing that my friendly Indie said he would clear the indicator for me. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
7th Jan 2015 1:28pm |
Hi Bob,
I have just sent an email to Barnett Davies who is the TF930 technical guy in the US. I'll drop you a note when I receive a reply. All the best, Andrew - Andrew - |
7th Jan 2015 3:03pm |
Thanks Andrew - much appreciated
7th Jan 2015 6:41pm |
7th Jan 2015 10:30pm |
Stu, you're very welcome sir and best of luck with the 29 other kg's that you need to make up
Bob: This is the reply from the US - Dear Andrew, Thank you very much for your email. And very nice to know that you like our Landrover scanner. However, I'm afraid our i930 Landrover scanner can not reset the service indicator on a Land Rover Defender 2012 TDCii . Sorry about that. Thank you very much for your support. Have a nice day. - Andrew - |
8th Jan 2015 10:22am |
Skeggy 90 Member Since: 07 Oct 2013 Location: Skeg Vegas Posts: 233 |
Had my one delivered today, it is a great little machine, works a treat on my Puma and my L322
Pics below, it does ABS but only from the TD5 menu, this is quite common with other code readers I have used previously. Best thing about it is that it is unlocked and without license, so if you have more than one vehicle it is an even bigger bargain. Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge 90 300 TDI SW (sold) 130 TD5 Utility (Foley SV) (sold) 110 TD5 Hardtop (sold) 110 TDCI Utility (sold) 1st Edition Range Rover Sport Supercharged Velar P380 HSE Discovery 1 V8 auto Puma 130 Double Cab (sold) R35 GTR Defender 110 300 TDI CSW (sold) 2010 110 XS Utility |
8th Jan 2015 12:49pm |
