Home > Puma (Tdci) > Bonnet springs open
Marius
South Africa 2011 Defender 110 Puma 2.4 SW Keswick Green
Bonnet springs open
My bonnets started to spring open driving heavy corrugated roads in the Kgalagadi. It closes fine and the safety does catch the bonnet so it doesn't open completely. Is there some sort of cable adjustment needed? Or are things not lined up correctly?
Post #381854 25th Dec 2014 7:23pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
I would clean it up and grease both the catch, and the bonnet pin,
Had this happen on a td5 at work, just lack of lube was fine afterwards! Smile
Also check alignment of bonnet pin and catch by removing the grille and checking.
Check cable for any slack and adjust as required.
Ian 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #381864 25th Dec 2014 8:02pm
vodonos
Slovenia 2012 Defender 110 Puma 2.2 SW Sumatra Black
regulate bonet hinges! BOŠTJAN
SLOVENIA
Cerknica lake
90 td5 2000
110 2,2 2012
Post #382088 26th Dec 2014 5:54pm
CatherineF
Ian
Need to do this with ours. Was looking at it the other day and thought it all looked a bit dry.
Post #382094 26th Dec 2014 6:09pm
ian series 1
Yep, one of the first things i done when i got mine,
when i went to look at it, i noticed how badly the bonnet opened and shut!
Post #382104 26th Dec 2014 6:49pm
