Home > Puma (Tdci) > EGR valve are noise since 10 days
gpauloj
France
hello,
since 10 days i noticed the egr valve make is particular noise who sounds like plastic rubber, the macanician here in South america said i cannot clean it, because its a "close box" can you help me on that? its true or not?
i can dismantle it myself, but after can i clean it? and with what i can clean it without damages?
thanks for help
Post #378570 13th Dec 2014 1:55am
Bonjour, Thumbs Up
Some people have cleaned them but are not often very successful.
For this reason most swap, this is why eventually I got a tune from Alive and got it shut off.
It's expensive and a sod to change, and it will fail again and again and couple to that it isn't very effective reducing emissions and it's no good to the engine.
Post #378599 13th Dec 2014 10:33am
gpauloj
France
hello, et bravo for the bonjour Smile
as i comment i'm in South america for almost one year, and i don't have in my road trip mecanicains who knows the car, my question is if i deconnect the electric connector, i'll get a light on dashbord, (till that point i understand) but i read in a site if i disconnect the electric connector, after a moment, i'll be in safe mode and only obd plug and default erase, will make the car back to normal., that's true? because if i get a safe mode and can run normally i'm stuck here.
thanks for your answer, answer as clear as possible Laughing
do i'll get stuck in safe mode if i disconnect electric plug?
do i'll have any problem afterworks if i disconnect?
thanks
Post #378636 13th Dec 2014 1:03pm
If you have EGR problems your only option is to change it, or tune and blank it.
Some have had sucess with just disconnecting it and blanking it but can be hit and miss.
If it's faulty, it'll still causes issues.
Post #378638 13th Dec 2014 1:14pm
