Home > Puma (Tdci) > EGR valve are noise since 10 days |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20488 |
Bonjour,
Some people have cleaned them but are not often very successful. For this reason most swap, this is why eventually I got a tune from Alive and got it shut off. It's expensive and a sod to change, and it will fail again and again and couple to that it isn't very effective reducing emissions and it's no good to the engine. |
13th Dec 2014 10:33am |
gpauloj Member Since: 13 Dec 2014 Location: evian Posts: 4 |
hello, et bravo for the bonjour
as i comment i'm in South america for almost one year, and i don't have in my road trip mecanicains who knows the car, my question is if i deconnect the electric connector, i'll get a light on dashbord, (till that point i understand) but i read in a site if i disconnect the electric connector, after a moment, i'll be in safe mode and only obd plug and default erase, will make the car back to normal., that's true? because if i get a safe mode and can run normally i'm stuck here. thanks for your answer, answer as clear as possible do i'll get stuck in safe mode if i disconnect electric plug? do i'll have any problem afterworks if i disconnect? thanks |
13th Dec 2014 1:03pm |
If you have EGR problems your only option is to change it, or tune and blank it.
Some have had sucess with just disconnecting it and blanking it but can be hit and miss. If it's faulty, it'll still causes issues. |
13th Dec 2014 1:14pm |
