Home > Puma (Tdci) > Location of inertia switch |
No inertia switch on Puma Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License |
25th May 2010 11:56am |
ralton Member Since: 04 Feb 2010 Location: Durban Posts: 153 |
wtf is an inertia switch? www.ralton.co.za
25th May 2010 12:47pm |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2651 |
if you smash your Td5, the inertia switch would kill the engine. You could only restart after you reset that switch. IIRC? |
25th May 2010 1:11pm |
Same thing that senses an impact and sets off airbags (in any other vehicle that is!). If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
25th May 2010 1:17pm |
ah, cool. funny thing with the anti-stall you'd think they'd have had an inertia switch fitted. when my clutch packed up i had a scary time trying to stop the beast!, had to turn off the ignition (fortunately before i hit the wall - might have pushed the wall over!). www.ralton.co.za
25th May 2010 1:19pm |
I misunderstood - it measures rapidly decreasing speed. It's not a manual switch (like the kill button on a motorcycle) to stop the engine.
Ignore my previous post... www.ralton.co.za |
25th May 2010 1:43pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6120 |
The switch on the Td5's has a small ball beearing inside it (if you take one off and shake it, you can hear it rattle around), like was said, a rapid deceleration (and maybe a "thump" at the end of it) will cause said ballbearing to jump out of its socket and kill the ECU & engine.
It's obviously well designed, as general off road use never seems to trigger it. Just looked through microcat, and indeed, there isn't one listed for puma's. |
25th May 2010 3:55pm |
bartv Member Since: 03 Oct 2010 Location: Belgium Posts: 12 |
Is there another system (instead of the inertia) that will cut the fuel after a crash?
And does it only cut the fuel or does it more? My roll-ver defender is not getting any fuel, but it does start when I give it fuel straight to the engine. |
22nd Nov 2010 6:03am |
Peter Td4 Member Since: 23 Oct 2010 Location: Antwerp, Belgium Posts: 228 |
Bart,
Did you check if the fuel pump is doing what it's supposed to do |
22nd Nov 2010 6:49am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6634 |
Is it a Puma or Td5? 1988 90 Td5 NAS soft top 2015 D90 XS SW |
22nd Nov 2010 10:06am |
Puma
22nd Nov 2010 11:33am |
