Home > Puma (Tdci) > Location of inertia switch
David128
Australia 2015 Defender 110 Puma 2.2 CSW Zermatt Silver
Does anybody know if the Puma has an inertia switch like the Td5 and if so, where is it located?
Post #32911 25th May 2010 11:26am
dgardel
Italy
No inertia switch on Puma Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #32914 25th May 2010 11:56am
ralton
South Africa 2007 Defender 90 Puma 2.4 SW Zermatt Silver
wtf is an inertia switch? Embarassed www.ralton.co.za
Post #32918 25th May 2010 12:47pm
Naks
if you smash your Td5, the inertia switch would kill the engine. You could only restart after you reset that switch. IIRC?
Post #32920 25th May 2010 1:11pm
K9F
Same thing that senses an impact and sets off airbags (in any other vehicle that is!).
Dog Thumbs Up Dog If you go through life with your head in the sand....all people will see is an ar5e!!
Post #32921 25th May 2010 1:17pm
ralton
ah, cool. funny thing with the anti-stall you'd think they'd have had an inertia switch fitted. when my clutch packed up i had a scary time trying to stop the beast!, had to turn off the ignition (fortunately before i hit the wall - might have pushed the wall over!). www.ralton.co.za
Post #32922 25th May 2010 1:19pm
ralton
I misunderstood - it measures rapidly decreasing speed. It's not a manual switch (like the kill button on a motorcycle) to stop the engine.
Ignore my previous post... www.ralton.co.za
Post #32924 25th May 2010 1:43pm
The switch on the Td5's has a small ball beearing inside it (if you take one off and shake it, you can hear it rattle around), like was said, a rapid deceleration (and maybe a "thump" at the end of it) will cause said ballbearing to jump out of its socket and kill the ECU & engine.
It's obviously well designed, as general off road use never seems to trigger it.
Just looked through microcat, and indeed, there isn't one listed for puma's.
Post #32933 25th May 2010 3:55pm
bartv
Is there another system (instead of the inertia) that will cut the fuel after a crash?
And does it only cut the fuel or does it more?
My roll-ver defender is not getting any fuel, but it does start when I give it fuel straight to the engine.
Post #45939 22nd Nov 2010 6:03am
Peter Td4
Belgium 2008 Defender 110 Puma 2.4 HCPU Santorini Black
Bart,
Did you check if the fuel pump is doing what it's supposed to do Question
Post #45940 22nd Nov 2010 6:49am
Martin
Site Admin
Is it a Puma or Td5?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #45949 22nd Nov 2010 10:06am
bartv
Puma
Post #45952 22nd Nov 2010 11:33am
