Home > Puma (Tdci) > Ford Parts |
Soupy Member Since: 05 Dec 2014 Location: Aberdeen Posts: 68 |
Further to the Ford parts, does anyone know if this will fit on a 2.4 puma?
http://www.ebay.co.uk/itm/FORD-TRANSIT-EGR...3a87a2fb69 Again, that's around 1/2 what LR want. |
3rd Feb 2015 3:33pm |
x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327 |
I'm pretty certain that that is the same EGR Valve as on the 2.4 Puma
If you refer to this other auction it shows you just how many other cars use the same EGR. http://www.ebay.co.uk/itm/LAND-ROVER-DEFEN...1243730581 Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
3rd Feb 2015 3:52pm |
Could be wrong here and I'm sure someone will correct/agree.
The (2.4) engine that was supplied by Ford to Land Rover is the higher powered transit lump as fitted to the Transit ST (and any other upgraded power vans) but then tune it to the Defender's specification. This engine has the Variable Vane Turbo that the standard Transit did not have. Therefore, if sourcing a Turbo via Ford, it has to be the Variable Vane one as fitted to the higher performance Transits. Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
4th Feb 2015 12:55pm |
Anyone confirm that? |
12th Feb 2015 11:34am |
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 981 |
What about the alternator?
Merlin |
12th Feb 2015 12:14pm |
fatman Member Since: 14 Jan 2014 Location: Athens-Greece Posts: 126 |
...that why the exhaust manifold is also different ,a 90 euro lesson learned |
12th Feb 2015 1:19pm |
So Ford makes 250,000 engines a year for Jaguar Land Rover under a contract that will come to an end in 2018.
What other vehicles does it go into? I thought the Ingenium engine would go into everything sooner that that? http://www.walesonline.co.uk/business/busi...nt-8919156 |
30th Mar 2015 11:30am |
250,000 engines doesn't sound a lot to me? When you consider how many of each model the factories are knocking out each day, I'd suspect they'd be using far more than this? Craig Rogers
30th Mar 2015 12:17pm |
GUM97 Member Since: 05 Feb 2012 Location: Cheshire Posts: 3555 |
Ford engines are currently in Defender and Evoque/Disco Sport. The idea behind implementing the Ingenium's is to bring them into new models only. So the new Disco 5 will have the Ingenium, and the next 16MY Upgraded Evoque etc. An engine to TDi for!
"Land Rover- Proudly turning drivers into mechanics since 1948" |
30th Mar 2015 5:57pm |
willy eckerslike Member Since: 15 Jun 2009 Location: North yorks Posts: 1789 |
Has the evoque engine changed recently then, thought it had the same engine as the freelander which isn't a ford. Original Member Pie n Pea Club.
110 HCPU Tipper |
30th Mar 2015 6:13pm |
Nope, Evoque currently on the original engine. Same as the Freelander, which is (and has been since Freelander 2), a 2.2 Ford Duratorq engine. An engine to TDi for!
30th Mar 2015 6:19pm |
PSA Original Member Pie n Pea Club.
110 HCPU Tipper |
30th Mar 2015 6:22pm |
Technically, it's a PSA/Ford engine seen as it's under the PSA/Ford joint-venture
Based on the PSA DW12 engine, designed by Ford, built in a PSA factory, then sold by Ford An engine to TDi for! "Land Rover- Proudly turning drivers into mechanics since 1948" |
30th Mar 2015 7:10pm |
Replacement turbo from transit.
Click image to enlarge |
1st Apr 2015 9:38am |
