Home > Puma (Tdci) > Ford Parts
Page 2 of 3 <123>
Soupy
Further to the Ford parts, does anyone know if this will fit on a 2.4 puma?
http://www.ebay.co.uk/itm/FORD-TRANSIT-EGR...3a87a2fb69
Again, that's around 1/2 what LR want.
Post #395475 3rd Feb 2015 3:33pm
x-isle
I'm pretty certain that that is the same EGR Valve as on the 2.4 Puma
If you refer to this other auction it shows you just how many other cars use the same EGR.
http://www.ebay.co.uk/itm/LAND-ROVER-DEFEN...1243730581 Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #395479 3rd Feb 2015 3:52pm
CRJ
Denmark 1991 Defender 90 200 Tdi ST Alpine White
Hi. It is the same Egr - I bought one here in Denmark at Ford it was 1/2 price. Regarding the turbo - Ford do have the same as on the Puma - they just have several different turbos so you have to be sure. I bought the oil return pipe at ford - also 1/2 price and in stock - Lr had several weeks delivery…
Regards
Christian 88 Ser. 3 1980 -sold
Puma 130 - 08- sold
90 200tdi 1991 - sold
88 Ser. 3 1977 200 TDI
110 CC 2003
Post #395698 4th Feb 2015 12:47pm
x-isle
Could be wrong here and I'm sure someone will correct/agree.
The (2.4) engine that was supplied by Ford to Land Rover is the higher powered transit lump as fitted to the Transit ST (and any other upgraded power vans) but then tune it to the Defender's specification.
This engine has the Variable Vane Turbo that the standard Transit did not have. Therefore, if sourcing a Turbo via Ford, it has to be the Variable Vane one as fitted to the higher performance Transits. Craig Rogers
2007 Puma 110 XS
Post #395705 4th Feb 2015 12:55pm
Soupy
Anyone confirm that?
Post #398100 12th Feb 2015 11:34am
Merlin
What about the alternator?
Merlin
Post #398109 12th Feb 2015 12:14pm
fatman
Greece 2007 Defender 110 Puma 2.4 USW Keswick Green
...that why the exhaust manifold is also different Evil or Very Mad ,a 90 euro lesson learned Big Cry
Post #398134 12th Feb 2015 1:19pm
250,000 engines a year for JLR
So Ford makes 250,000 engines a year for Jaguar Land Rover under a contract that will come to an end in 2018.
What other vehicles does it go into? I thought the Ingenium engine would go into everything sooner that that?
http://www.walesonline.co.uk/business/busi...nt-8919156
Post #412297 30th Mar 2015 11:30am
x-isle
250,000 engines doesn't sound a lot to me? When you consider how many of each model the factories are knocking out each day, I'd suspect they'd be using far more than this? Craig Rogers
2007 Puma 110 XS
Post #412314 30th Mar 2015 12:17pm
GUM97
Ford engines are currently in Defender and Evoque/Disco Sport. The idea behind implementing the Ingenium's is to bring them into new models only. So the new Disco 5 will have the Ingenium, and the next 16MY Upgraded Evoque etc. An engine to TDi for!
Post #412388 30th Mar 2015 5:57pm
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
Has the evoque engine changed recently then, thought it had the same engine as the freelander which isn't a ford. Original Member Pie n Pea Club.
110 HCPU Tipper
Post #412395 30th Mar 2015 6:13pm
GUM97
Nope, Evoque currently on the original engine. Same as the Freelander, which is (and has been since Freelander 2), a 2.2 Ford Duratorq engine. An engine to TDi for!
Post #412399 30th Mar 2015 6:19pm
willy eckerslike
PSA Whistle Original Member Pie n Pea Club.
110 HCPU Tipper
Post #412402 30th Mar 2015 6:22pm
GUM97
Technically, it's a PSA/Ford engine seen as it's under the PSA/Ford joint-venture Wink
Based on the PSA DW12 engine, designed by Ford, built in a PSA factory, then sold by Ford Wink Wink An engine to TDi for!
Post #412423 30th Mar 2015 7:10pm
fatman
Replacement turbo from transit.
Post #412916 1st Apr 2015 9:38am
Page 2 of 3 <123>
