Home > Maintenance & Modifications > Rear brake pads
Page 4 of 4 <1234
Caterham
Had new caliper and pads fitted.
Only done a few miles since but ran perfect on return as it did there.
Will be braking cautiously for the next few miles but likely to be doing c500 miles this week so can hopefully report back some good news.
Did the guy with odd brakes simply have different aged calipers or different models?
If all goes well and def continues to run well I might be looking to upgrade both the go and stop performance Mr. Green
Post #387124 10th Jan 2015 6:23pm
RobKeay
Think they were different ages.
Post #387142 10th Jan 2015 6:48pm
Caterham
Oh....
That said my good one is only 4 years old and further more I'm very comfortable with the advice I was given.
Will keep you posted once bedded in.
Post #387146 10th Jan 2015 7:02pm
munch90
if the caliper was faulty due to rust then maybe worth fitting a pair
if it was damaged due to someone doing something they don't know about then thats different Whistle Whistle
if the caliper is the right model , piston size , etc then there should be no problem in fitting one caliper
as for the person who fitted one caliper and having a accident , was it the right model? , was piston size right? , was it secondhand? , was it secondhand and seized ?, were pads fitted rights , were pads a new set? , was it bled right? the list could go on and on
I would guess 99.9% of garages would fit one caliper , because if they said you needed to fit a pair then most people would accuse them of ripping them off !!
things you should fit in pairs/axle sets
pads
shoes
discs
drums
Post #387183 10th Jan 2015 8:15pm
Caterham
it's remotely possible 'someone' did something they didn't know what they were doing Whistle
anyhow one new caliper fitted and as you've probably already guessed I'm happy to trial it.....as ever I'll adopt the 'suck it and see approach'......after all it's only the brakes - what could possibly go wrong?
its the loud pedal that can cause the problems.
ps. Happy New Year to you all and safe motoring Thumbs Up
Post #387240 10th Jan 2015 10:11pm
Happyoldgit
The circumstances of the unfortunate accident in which several children were killed are easily found on the net and were widely discussed on the various forums that existed at the time and subsequently, consequently I personally see no need to rehash it all when it's already all out there. The driver and owner of the vehicle concerned was well known on several forums. Steve.
http://forums.lr4x4.com
Post #387248 10th Jan 2015 10:28pm
Happyoldgit
Don't even joke about it Shocked Steve.
Post #387252 10th Jan 2015 10:31pm
Caterham
Sorry Steve you're right.
I often forget there's odd person out there that can go prove to be more inept than myself and as such I should refrain from such jokes.
Furtheremore I might read this post next week having fully forgotten that I was joking.....
Thumbs Up
Post #387321 11th Jan 2015 8:46am
HardCharger
Hi All,
Just a question, I recently replaced the front brake pads and they came with wire spring thingies, since the guy who was doing the install was having a difficult time putting them on, he said that I didn't need them anyways and could leave them out, I saved them though, can anyone tell me what these spring thingies are for? I don't seem to recall the rear brake pads have them.
Also, I have uneven wear on the left front disc (rotor), one side of the rotor is a bit thinner than the other. Any ideas how that happened? The right one seemed OK.
Post #387713 12th Jan 2015 1:52pm
mk1collector
The springs are to stop the pads rattling in the caliper and when your window is open in summer and you hit bumps or potholes the noise will drive you mad so best to get them fitted.
Post #387719 12th Jan 2015 2:50pm
jimbob7
HardCharger wrote:
Hi All,
I'd find another garage,if you can tie your own shoelaces you can fit the pad retaining springs Shocked . Pov.spec,ftw. 2006, 110,TD5.
Post #387750 12th Jan 2015 5:08pm
HardCharger
Thanks guys! Will get right on it at the first possible opportunity.
Post #390081 19th Jan 2015 6:21am
Lou Sparts
pads
shoes
discs
drums
Springs
Dampers
Tyres 2005 Td5 90 XS
Steve
Post #390139 19th Jan 2015 10:35am
Gonarezhou
South Africa 2015 Defender 110 Puma 2.2 SW Alaska White
From about 500km the brake rattle started. Dealer replaced the rear callipers at 2500km and the brake rattle has gone....for now. I suspect that some are not machined properly at the factory and there is probably a bad batch or two floating around.
Post #429026 6th Jun 2015 4:34pm
Page 4 of 4 <1234
