Home > Maintenance & Modifications > Rear brake pads
Page 3 of 4 <1234>
munch90
you need to find out if its oil or brake fluid
you don't need much of either to make a mess
you need to get this checked properly , my advise is take it to a garage !
you say its the third time the brake fluid light has come on , how did you fix this before then ? did you add fluid ?
Post #386655 9th Jan 2015 8:04am
Caterham
It came on twice for only 2 or 3 seconds coming down Hardknock Pass and same last night....on a very down hill for just a couple of seconds and then went away.
Got home and checked levels and front o/s wheel / disc and oil type fluid everywhere and dripping from caliper so I assume it's brake fluid.
I can only assume it's coincidence but I've often thought my def has had some kind of electronic / electrical issue with the brakes which as we know links into the ecm and hence the cause of poor running - well hey presto was running sweet as a nut this morning.....even the rumble sound that is usually associated with the hand brake when slowing down seemed to have gone??????
Post #386662 9th Jan 2015 8:45am
munch90
DONT DRIVE IT
good chance you damaged a seal when fitting pads
guessing as you pushed one piston in the other came out to far !
new caliper needed then and new set of pads because fluid will have soaked in to new ones already fitted
and give the hub and disc a good wash off with traffic film remover , don't bother trying to clean it off with proper brake cleaner
good wash ( you cant wash it too much give it a few goes ) with tfr and then water hose let it dry then final rinse with brake cleaner
don't forget that brake fluid WILL be damaging the paint on the wheel
Post #386666 9th Jan 2015 9:14am
Caterham
much90 disappointly I suspect you're bang on. albeit I'm a little surprised as I was conscious of that happening and since the pads were only half worn I'm surprised that any of the piston would have come out very far?
I need to go of and do a search now as someone mentioned a stainless steel piston kit which is rather appealing. Off to garage tomorrow and would be good to have the parts needed before then?
Post #386667 9th Jan 2015 9:20am
munch90
really in future you need to push the pad back as this will push both pistons back together
guessing you have pulled both old pads out then pushed pistons back , should really leave one pad in to stop pistons comimg out to far
I replaced all my pistons with stainless ones
Post #386668 9th Jan 2015 9:26am
Caterham
once again you're right.
quite fancy the s/s piston myself. see what happens tomoz at garage.
I wonder if I can get some s/s pistons delivered for first thing tomoz?
Post #386674 9th Jan 2015 10:15am
Caterham
ooph !
just read the bit about the paint on the wheel and the 'don't drive it'.....I'm at work with it and need to get it to the garage?
Post #386676 9th Jan 2015 10:17am
Happyoldgit
So what's the verdict then Wayne? Steve.
http://forums.lr4x4.com
Post #386961 10th Jan 2015 10:47am
Caterham
Popped a seal on piston is initial feed back.
In keyboard class at moment. Will feedback later when I know more.
Thumbs Up
Almost tempted to leave as is a just drive slowly as its running perfectly at the moment ??????
Post #386970 10th Jan 2015 11:07am
munch90
don't be silly Caterham , would you want a defender heading towards your kids with the driver knowing it has faulty brakes !!
Post #386972 10th Jan 2015 11:18am
Caterham
Sorry mate. Was only a silly joke.
Off road now till fixed Thumbs Up
Post #386973 10th Jan 2015 11:21am
Happyoldgit
By someone who has a clue what they are doing hopefully Mr. Green Steve.
Post #386995 10th Jan 2015 12:29pm
Caterham
Steve is that a polite way of saying I shouldn't be doing it?
Or simply to ensure whoever is doing it for me is competent?
I've got a top guy on the job so no concerns there Razz
Hopefully back on the road later today with new caliper.....i did suggest putting one of the back ones on the front as the fronts do most of the braking but got an unusual look back - think it was his way of suggesting it might be better in the long run just to get a new now?
Post #387023 10th Jan 2015 1:53pm
Happyoldgit
If the person you are using is competent and knows Defenders I'd take his advice but for you, your family and other road users sake it might be an idea to get any other braking components that you have tinkered with checked as well. I was taught to replace calipers in axle pairs meaning not replace just one side. Steve.
Post #387095 10th Jan 2015 5:48pm
RobKeay
Yeah if you are going to change anything to do with brakes it must be done in pairs.
There was a bloke in a 110 killed his kids because of odd calipers. Please be careful.
Post #387121 10th Jan 2015 6:14pm
Page 3 of 4 <1234>
