Home > Puma (Tdci) > MY2011/2012 Recall Action P047/048 Front Axle Case
Page 20 of 39 <123 ... 192021 ... 373839>
XS Pete
England 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
I got one of these today too Surprised
Post #1008455 22nd Sep 2023 10:56am
Re: Got my recall today. 2012 110
keith wrote:
That first paragraph is sickening in its hypocrisy. What it really means, translated from industry media-speak, is that "we are reluctantly being forced by European authorities to address in a half-hearted and condescending way a life-threatening issue which we have known about and failed to address properly for at least nine years".
"Ongoing quality assessments and improvements" my arse! They are only doing this because they will end up in court if they don't. Shocking, shameful, and exactly what we have come to expect. Very sad times.
I wonder what the Wilkes brothers would have said. Never again will I buy a new product from Jaguar Land-Rover.
Post #1008492 22nd Sep 2023 4:17pm
Ianh
Do the brackets actually reinforce the axle case as they state, preventing it shearing at the weld ? or do the brackets just stop the sheared bit of the axle plus swivel, hub, wheel etc totally collapsing and flying off when it does ?
I’m sure it’s the latter, in which case this is a child like cynical attempt to word the solution as a rectification of the cause !
Post #1008497 22nd Sep 2023 4:36pm
The brackets are designed to retain the failed part rather than to prevent it failing in the first place, although it is possible that they may marginally reduce the likelihood of the failure occurring. In the even of the weld failing, the brackets will retain the hub assembly in place and allow the vehicle to be controlled normally, probably to the extent that the driver will be unaware of the failure. It is almost certain that there will be a tell-tale oil leak, and the bracket is designed so that this will be visible.
I have not heard of a vehicle with the brackets fitted subsequently failing, although there seems to be no reason why it can't. I do also wonder what JLR's reaction would be if you did find yourself in this situation, I don't see that they would have much choice but to replace the axle. The original recall did replace axles which had cracked, and fitted brackets to those which had no visible defect.
At one time it had become very hard to obtain the brackets, I think the limited supply had dried up. I presume that JLR must have had a further batch made.
Post #1008499 22nd Sep 2023 5:01pm
Dinnu
NO, they do not reinforce the axle.
If you have the brackets, and you feel a wobble in the steering, do not hit the brakes, as they too will fail - keep in mind that when the axle fail, the brackets need to take the weight, plus whichever wheel trying to part with the vehicle due to a huge toe out. The brakes would be the last straw. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1008501 22nd Sep 2023 5:04pm
nidge n
So my 110 goes in next week for the necessary bracket fix. I am going to ask the dealer to inspect the axle case and certify that it's ok. (Crack free) What else should we be pushing for during this recall visit? If we are investing time to get this thing sorted, what else should we be pushing the dealer to do/advise or recommend?
Thanks all
N
Post #1008524 22nd Sep 2023 7:20pm
Dinnu
I tried that with my local authorized dealer Banging Head 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1008529 22nd Sep 2023 7:58pm
Dinnu
For those who have not received the letter (like me), I went onto https://osh.landrover.com/ and entered my VIN number. There it popped up the Outstanding Recalls - ❗ Safety recall - N706 - FRONT AXLE REINFORCEMENT BRACKET. Please contact your local authorised repairer.
I have called my authorised repairer, and they are ordering the brackets and I am booked for 1 month from now. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1008564 23rd Sep 2023 9:42am
Ianh
Was it under the “outstanding alerts” section on the main page ?
I just looked up my vin and there is nothing about a recall for my 2013 2.2. I know I’m out of the vin range by 4 days but I really don’t think JLR have sufficiently accurate records to be accurate “to the day” when they stopped fitting faulty axles .
So what’s involved in fitting the brackets as I may just buy and fit myself.
Post #1008580 23rd Sep 2023 1:03pm
Dinnu
If I do it from the phone, but similar on PC.
Never installed brackets myself, but installing the brackets is very simple. Just remove the nuts that bolt the axle to the radius arms, slide in the brackets, and re do the nuts to the correct torque. Does not even need to lift a wheel off the ground. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1008593 23rd Sep 2023 3:33pm
MK
Somehow I have those brackets in a shelf. Mine it is an early Puma so the thing friction welded. Anyway, those brackets are extremely light. Not sure what they are made off. Puma 110" SW
Post #1008594 23rd Sep 2023 3:42pm
Dinnu
Perhaps these comments are related.
Payney1000 wrote:
The brackets that was tested in the Lab are just a joke they lasted less than 8 sec at driving at 60 miles a hour in the test frame.
Post #1008596 23rd Sep 2023 4:03pm
LR90XS2011
came home to my letter this afternoon, not sure what to do as I already fitted them!! DEFENDER 90 TDCI XS,
Post #1008605 23rd Sep 2023 5:12pm
Ianh
Thanks Dinnu, I was wondering if I needed longer bolts , or if anything needed removing to get the bolts out. If not seems an easy to fit solution if I get the brackets and fit myself, just in case my axle casing is defective even if outside the JLR recall
Post #1008633 23rd Sep 2023 10:04pm
Dinnu
The bolts do not need to be removed, although it is not a bad idea to pull them out one at a time and apply some anti seize. It is also recommended to use new nuts (M16x1.5). Given that the brackets have a counterbore, a flanged nut might not fit anymore. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1008634 23rd Sep 2023 10:11pm
