Home > Puma (Tdci) > MY2011/2012 Recall Action P047/048 Front Axle Case
Page 8 of 39 <123 ... 789 ... 373839>
MikeJ
United Kingdom 2013 Defender 130 Puma 2.2 HCPU Fuji White
It's a 2.2, 2013 model (62 plate) so well out of warranty.
The conversion is an LR approved one by Versalift, so that's not an issue.
I think we might try and re-weld it, but I'm pricing a new tube as well.
Mike
Post #641161 1st Aug 2017 2:32pm
I imagine that if you removed the axle case (which isn't as big a job as it sounds) and cleaned it thoroughly, you could then get a competent welder to a good full penetration weld, possibly J-prep or similar, with an NDT afterwards. You'd then probably have a better weld than the original. You could reinforce the axle case at the same time, provided that you didn't inadvertently distort it.
It strikes me as quite a disturbing failure, unless the axle has been clobbered by something. At least the end flanges haven't broken off yet, somethign else I'd be inclined to reinforce.
It's a very nice Defender. by the way, a handy piece of kit too! Thumbs Up
Post #641174 1st Aug 2017 4:00pm
zsd-puma
In corrected jacking at some point is a possibility too in that location i think.
Post #641186 1st Aug 2017 4:50pm
MikeJ
We decided to clean it all off and have a better look. The crack was almost the whole length from the diff to the inner brackets.
Having got this far, we drained the oil, cleaned the crack up and welded it shut. It took a couple of goes to get it to seal due to residual oil on the inside, but a small blast of an airline into the breather hole to check for bubbles helped prove it was sealed.
So, we'll wait and see how it goes. If it comes to taking the axle tube off, then having gone to that trouble, we'll replace it rather than try and weld it again.
Fingers crossed!
Mike
Post #641259 1st Aug 2017 8:39pm
Caterham
Blimey!
Hope the repai holds but as suggested previously i'd be very inclined to consider the military mod of welding a vertical strip of metal plate below.
Post #641323 2nd Aug 2017 6:41am
spudfan
Ireland
You would think that Land Rover would have come on board with this issue. All they had to say was "Never came across this issue before but seeing as it is such a vital component we'll replace it". Would not cost them a huge amount. The bigger and more successful sales wise they have become, the more remote from their customers.
Hope you get it sorted. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #641558 3rd Aug 2017 10:47am
Bluericky
United Kingdom 2009 Defender 110 Puma 2.4 DCPU Keswick Green
Complete fail of the axle casing this afternoon. I’d been travelling on an A road at 60 for the past hour and only started to feel it going as I slowed to take a country lane thank goodness ! If it had gone earlier I my not be typing this post !!
Post #735578 18th Oct 2018 6:16pm
spudfan
Ireland
Shocked Neutral If you take this up with Solihull keep us informed. I'd say this is a scenario that Land Rover thought could possibly happen but that the odds were against it. Looks like you drew the short straw that proves Land Rover wrong.
You are probably still getting over the shock and thanking your lucky stars the way things worked out. I have had the magic brackets fitted but I'd say that the vehicle would be hard to control if this occurred to it. Maybe we will see a recall now and the axle casings replaced.
Best of luck...and you had it in spades today!!! 1982 88" 2.25 diesel
Post #735584 18th Oct 2018 6:31pm
Bluericky
Thank you Spudfan , I certainly had a bit of luck today.
Any idea who I’d take it up with at Land Rover , for me it’s not necessarily the financial loss as that’s to be expected with an older car but the implications of a failure in the face of oncoming traffic could be fatal .
For your information the landy went from driveable to undriveable over the course of 200 meters . If you’d been traveling at 60 on a single carriageway then you’d not have been able to correct it . There were next to no warning signs in terms of handling , perhaps a very slight feeling that the tracking was out
I’m certainly going to make Land Rover aware of this , if not for me then for every other owner of a 2009 110!
Post #735595 18th Oct 2018 7:04pm
spudfan
Ireland
First thing I'd do is to get onto the Land Rover customer services contact on this site. This is a known defect that they had hoped to minimise with the brackets. I do not think age will have anything to do with it. If your vehicle falls within the VIN range of vehicles they thought might be effected I'd say they will have to effect repairs. This could be the start of a major recall.
Like you say, you were lucky today but under different circumstances the results could have been infinitely worse. I do not think they would like an investigation into a serious road accident to come to the conclusion that it was caused by a known defect that they addressed in a half hearted manner.
They knew this could come but now it has arrived. Expect some serious conversations in Solihull.
Maybe you should buy a Lotto ticket tonight....as you were very very lucky today. I had a tyre blow out on the company van and though I was going slow on a country lane, handling was interesting to say the least so trying to control this on a Defender does not bear thinking about.
So get your e-mail off complete with photos and remind them of the safety recall. I'd say on this issue now there will be serious movement. 1982 88" 2.25 diesel
Post #735601 18th Oct 2018 7:23pm
I don't think that LR customer services pay any attention to this forum any more, I haven't seen any involvement from them for ages.
I'm pretty sure that an '09 is outside the range involved in the recall, which makes this more disturbing. Is the vehicle modified (the springs and shocks don't look original)? Does it get used heavily?
Post #735639 18th Oct 2018 9:22pm
spudfan
Ireland
I suppose it will have to go directly to Land Rover. Wonder what contact e-mail it would be best to use? This is a serious safety concern so I am assuming they will want to get it rectified. Wo'nt do the marketing of their new vehicles any good so it should be addressed quickly by the powers that be. 1982 88" 2.25 diesel
Post #735646 18th Oct 2018 9:55pm
I think you may be in for a disappointing lack of interest from LR and a frustrating time, but I really hope I am wrong!
Please keep us informed.
Post #735648 18th Oct 2018 9:57pm
Bluericky
Black Wolf,
I haven’t had it from new but in my ownership it’s used as a daily drive for me and occasionally to tow some fairly light loads . Mechanically it’s completely standard other than the Bilstein B6 shocks , the springs are OEM . It’s had a winch on in the past . There’s no way that my usage is reflected in this failure .
The big giveaway had I been aware of this problem was the fluid leak , although I thought it was coming from the seal next to it!
Having been a Land Rover owner for quite some time, I tend not to panick at the first sign of a leak !!!
Post #735653 18th Oct 2018 10:10pm
Thanks for the update, it is concerning that there are clearly duff axle cases that are far outside the range identified by JLR. I hope that JLR takes your case seriously, unfortunately they have a very poor track record in this regard.
Post #735670 19th Oct 2018 7:58am
