Home > Puma (Tdci) > Another one with worn splines!!
Page 1 of 6 123456>
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Just thought i would post these pictures of the 2010, 90 that came into work today for the dreaded "rattly gear box problem"
Clutch springs were shot, and the splines on the shaft very dry and starting to wear.
It had covered just 31,000 miles! Big Cry
 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #373968 24th Nov 2014 7:43pm
It does not look like it's ever been greased..
Post #373988 24th Nov 2014 8:35pm
keith
My 2012 with 25000 miles has now had 3 transfer , 2 main boxes and 2 clutches and 2 front diffs . Always the same symptoms as you .
Post #373990 24th Nov 2014 8:42pm
ian series 1
BLIMEY!!!!
I think i would have lost faith in Land Rover after that little lot!!!!
Splines were as dry as a bone, why on earth they thought lubrication was not needed is beyond me?
Now im thinking should i drop the box in mine to see what they are like! although i have no noise or gear change issues, im thinking "if it aint broke" type of thing!!!
Ian 80" 80" 86" 88" 90"
Post #373997 24th Nov 2014 8:52pm
It doesn't take long to drop the transfer box to check and lube the splines and it'll give you peace of mind.
Post #374000 24th Nov 2014 9:07pm
Venomator
Okay, so I am aware that moving metal parts generally require some form of lubrication... Whistle
What I am failing to comprehend is why these bits have absolutely none?
Are they not checked/lubed as part of the normal servicing regime, or what... Shocked
Or am I just being a dipstick... Rolling Eyes
 Rog... Mr. Green
The GREEN One...
MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color]
Post #374002 24th Nov 2014 9:13pm
Earlier Puma's avoided this issue but 10 and 11 seem to be very prone.
Post #374003 24th Nov 2014 9:15pm
ian series 1
The shaft is in the gearbox, the last time it saw the light of day is on the production line, so not really a service item, unless you remove and split the box to have a look,
ian 80" 80" 86" 88" 90"
Post #374006 24th Nov 2014 9:20pm
Venomator
Ah, thanks Ian... Thumbs Up
So does that mean I should worry about MY2010 Mamba?... Big Cry
 Rog... Mr. Green
The GREEN One...
Post #374008 24th Nov 2014 9:22pm
ian series 1
I didnt know that, so my 08 may be ok? as i said it makes no noise, and is nice and smooth through the gears,
Maybe i will leave it alone! Whistle
Post #374011 24th Nov 2014 9:23pm
Get it done if you have a clutch change, that's what I did.
Mines a 57 and there was no wear on mine but I asked them to Moly grease it anyway.
Seems nice and smooth now, anyway but it would do with a new clutch and all sorts I've had done on it.
As I said it seems like 10 and 11 years seem the ones with the issues regarding this.
Post #374012 24th Nov 2014 9:24pm
ian series 1
Re: ^ ^ ^
Probably!!!! Rolling Eyes
Sorry to be the bearer of bad news, the person who owns this 90 has 2 others in his fleet of work trucks, one has been done 6 months ago, and the splines were pretty much gone!
This one is a bit slack but not too bad, i think im doing the other 90 next week, so will be interesting to compare all three, they are all 10 plates with around the same miles. 80" 80" 86" 88" 90"
Post #374014 24th Nov 2014 9:27pm
Venomator
Lovely!?!... Big Cry
Any external/early warning signs I should be looking out for Ian, or asking my dealer to check, I am still just inside their pre-loved warranty?... Shocked
 Rog... Mr. Green
The GREEN One...
Post #374018 24th Nov 2014 9:36pm
munch90
I took my t/box out to check after putting a camera in the casing and could see a small bit of brown dust , just greased it and refitted
Post #374019 24th Nov 2014 9:44pm
ian series 1
Re: ^ ^ ^
This one was quite noisy, when i drove it in the workshop it sounded quite rattly, sounded like clutch plate springs, (which were shot) i didnt get to talk to the driver, i will try and get more info as to symptoms tomorrow and let you know!
Post #374022 24th Nov 2014 10:00pm
Page 1 of 6 123456>
