![]() | Home > Puma (Tdci) > Another one with worn splines!! |
It does not look like it's ever been greased..
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2237 ![]() ![]() |
My 2012 with 25000 miles has now had 3 transfer , 2 main boxes and 2 clutches and 2 front diffs . Always the same symptoms as you .
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
BLIMEY!!!!
I think i would have lost faith in Land Rover after that little lot!!!! Splines were as dry as a bone, why on earth they thought lubrication was not needed is beyond me? Now im thinking should i drop the box in mine to see what they are like! although i have no noise or gear change issues, im thinking "if it aint broke" type of thing!!! Ian 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17680 ![]() ![]() ![]() |
It doesn't take long to drop the transfer box to check and lube the splines and it'll give you peace of mind.
Venomator Member Since: 25 Aug 2014 Location: Peterborough Posts: 2087 ![]() ![]() |
Okay, so I am aware that moving metal parts generally require some form of lubrication...
![]() What I am failing to comprehend is why these bits have absolutely none? Are they not checked/lubed as part of the normal servicing regime, or what... ![]() Or am I just being a dipstick... ![]() ![]() The GREEN One... MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color] |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20706 ![]() ![]() |
Earlier Puma's avoided this issue but 10 and 11 seem to be very prone.
The shaft is in the gearbox, the last time it saw the light of day is on the production line, so not really a service item, unless you remove and split the box to have a look, ian 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
Ah, thanks Ian...
![]() So does that mean I should worry about MY2010 Mamba?... ![]() ![]() The GREEN One... MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color] |
I didnt know that, so my 08 may be ok? as i said it makes no noise, and is nice and smooth through the gears, Maybe i will leave it alone! ![]() ian 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
Get it done if you have a clutch change, that's what I did.
Mines a 57 and there was no wear on mine but I asked them to Moly grease it anyway. Seems nice and smooth now, anyway but it would do with a new clutch and all sorts I've had done on it. As I said it seems like 10 and 11 years seem the ones with the issues regarding this. Last edited by custom90 on 24th Nov 2014 9:30pm. Edited 1 time in total |
Probably!!!! ![]() Sorry to be the bearer of bad news, the person who owns this 90 has 2 others in his fleet of work trucks, one has been done 6 months ago, and the splines were pretty much gone! This one is a bit slack but not too bad, i think im doing the other 90 next week, so will be interesting to compare all three, they are all 10 plates with around the same miles. 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
Lovely!?!...
![]() Any external/early warning signs I should be looking out for Ian, or asking my dealer to check, I am still just inside their pre-loved warranty?... ![]() ![]() The GREEN One... MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color] |
I took my t/box out to check after putting a camera in the casing and could see a small bit of brown dust , just greased it and refitted
This one was quite noisy, when i drove it in the workshop it sounded quite rattly, sounded like clutch plate springs, (which were shot) i didnt get to talk to the driver, i will try and get more info as to symptoms tomorrow and let you know! Ian 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
