![]() | Home > Td5 > Main beam issue |
is wiring standard or been relayed ?
if standard wont be a fuse as same fuse for main and flash , its more than likely in the switch ( indicator switch not main switch ) |
Have a look here,
http://www.defender2.net/forum/topic16451....ght+switch http://www.defender2.net/forum/topic24666....ght+switch http://www.defender2.net/forum/topic13683....ch[/quote] There is a replacement harness that makes your lights 'brighter' that comes with a switch. Pinched from yet another thread! Sorry it's in Dutch there may be a provider in the UK. Good luck! ![]() http://api.viglink.com/api/click?format=go...elaar.html If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 20th Nov 2014 5:04pm. Edited 1 time in total |
k9f your links are for main headlight switch , his problem is flash not working main/dip beam is , so cant see how its a headlight switch , more a indicator dip/main/flash stalk/switch problem
My mistake.
![]() ![]() Could always drop 'Ze' a pm and see what his issue was perhaps as he suffered the same affliction? http://www.defender2.net/forum/topic31245....ight+flash If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Mac87 Member Since: 06 Nov 2013 Location: Kent Posts: 64 ![]() ![]() |
Cheers, was wondering if it was a common fault for the indicator stalk/flash etc to play up. It's MOT time next week and I'm finding more and more things wrong, could be a busy weekend!
rustyboxx Member Since: 08 Oct 2012 Location: Poole Posts: 548 ![]() ![]() ![]() |
I recently had a similar problem with the flash not working, main beam was ok though. All it took was a gentle tweak of the sprung contact in the switch and job done. Works perfectly now.
Might be worth giving it a go if only as part of the process of elimination ![]() 2007 110 XS DCPU - An itch that needed scratching 2005 90 Td5 XS CSW - Utterly brilliant 2001 Discovery 2 ES Auto - A phase I went through 1996 90 Tdi CSW - Uber reliable 1989 90 2.5 Petrol Hardtop - My first proper Landy 1985 Range Rover Vogue V8 -Troublesome |
