Home > Td5 > Main beam issue
Mac87
Main beam issue
Hi chaps, new problem. All my lights work fine, dipped beam etc. However the main beam 'flash' doesn't work, but the main beam works fine when it's 'locked on' with the normal dipped headlights on. (Hope that made sense!!) Any ideas? had a brief check of fuses etc all is fine, is it likely to be the switch?
Post #373027 20th Nov 2014 2:55pm
munch90
is wiring standard or been relayed ?
if standard
wont be a fuse as same fuse for main and flash , its more than likely in the switch ( indicator switch not main switch )
Post #373030 20th Nov 2014 3:15pm
K9F
Have a look here,
http://www.defender2.net/forum/topic16451....ght+switch
http://www.defender2.net/forum/topic24666....ght+switch
http://www.defender2.net/forum/topic13683....ch[/quote]
There is a replacement harness that makes your lights 'brighter' that comes with a switch. Pinched from yet another thread! Sorry it's in Dutch there may be a provider in the UK.
Good luck! Thumbs Up
http://api.viglink.com/api/click?format=go...elaar.html If you go through life with your head in the sand....all people will see is an ar5e!!
Post #373052 20th Nov 2014 4:56pm
munch90
k9f your links are for main headlight switch , his problem is flash not working main/dip beam is , so cant see how its a headlight switch , more a indicator dip/main/flash stalk/switch problem
Post #373056 20th Nov 2014 5:03pm
K9F
My mistake. Embarassed Agree! Thumbs Up
Could always drop 'Ze' a pm and see what his issue was perhaps as he suffered the same affliction?
http://www.defender2.net/forum/topic31245....ight+flash If you go through life with your head in the sand....all people will see is an ar5e!!
Post #373057 20th Nov 2014 5:06pm
Mac87
Cheers, was wondering if it was a common fault for the indicator stalk/flash etc to play up. It's MOT time next week and I'm finding more and more things wrong, could be a busy weekend!
Post #373091 20th Nov 2014 6:41pm
rustyboxx
United Kingdom 2015 Defender 90 Puma 2.2 CSW Montalcino Red
I recently had a similar problem with the flash not working, main beam was ok though. All it took was a gentle tweak of the sprung contact in the switch and job done. Works perfectly now.
Might be worth giving it a go if only as part of the process of elimination Thumbs Up 2015 90 XS CSW TDCi - Beautiful
2007 110 XS DCPU - An itch that needed scratching
2005 90 Td5 XS CSW - Utterly brilliant
2001 Discovery 2 ES Auto - A phase I went through
1996 90 Tdi CSW - Uber reliable
1989 90 2.5 Petrol Hardtop - My first proper Landy
1985 Range Rover Vogue V8 -Troublesome
Post #373095 20th Nov 2014 6:55pm
