Home > Land Rover Customer Relations > Track Rod Snap! (not the rod end)
Kevzeboy
United Kingdom 2011 Defender 110 Puma 2.4 USW Indus Silver
I had a Track Rod snap on my Defender a month after it was out of its three year warranty! That's right, a track rod and not a rod end.
It was metal fatigue at the end of the threaded part of the rod.
It was a properly scary experience!
Is it worth a letter to LR with chassis numbers and pictures or will they just say sod off?
It had been service two weeks before and rods and ends checked!
And thoughts?
Kevin
Post #372595 18th Nov 2014 9:51pm
Tiger
If its metal fatigue due to manufacturing fault i'm pretty sure LR would be interested. They obviously buy these parts and need to know about critical safety issues such as this. You might not be the only one.
Post #372674 19th Nov 2014 9:29am
Raise a thread in the Customer Relations forum here. Add a photo or two of the damaged ends so we can all see.
It can be very difficult/near impossible to see this damage before a catastrophic failure.
Obvious question, how have you been driving it?
Post #372712 19th Nov 2014 11:00am
CRC@LandRover
Verified Account
Verified Account
Hi Kevzeboy
I am sorry to hear about your concern. I would be more than happy to look into this further.
Can you please send me a PM with the following information.
Full name:
Contact No:
Contact Email:
Vehicle Reg:
Last 6 Vin:
Repairing Retailer:
Many thanks,
Ryan
Post #373053 20th Nov 2014 4:56pm
X4SKP
Hello Kevzeboy
Scary... I bet Exclamation if at speed or when cornering (under load), this could have been much worse.
If it is a metal fatigue fracture, then it is almost impossible to see with any kind of visual inspection,
before it lets go.
Normally only NDT (non destructive testing) with a trained 'operator' would stand a chance of seeing
this before full failure.
The quality of the steel and manufacturing process can vary between the batch production of components
so it is only by reporting this, that JLR can monitor failures and take appropriate action if required...
Definitely follow this up. SKIP
Post #373062 20th Nov 2014 5:19pm
