Home > Technical > Check your rear ABS sensor lines |
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 |
Installed air bag spring inserts (Polyairs) in the rear of the Puma today and whilst getting the springs in and out and cleaning everything I noted the ABS sensor lines for the rear wheels curve around the edge of the lower spring mount. This last section of the wiring is not covered by conduit and I notice it had a slight wear mark on the insulation. It hadn't worn through by a long way but it would eventually I'd guess.
I suspect this applies to both Td5 and Puma Defenders unless it is just the Puma and Ford skimping on 6" extra of conduit per rear wheel. Suffice to say mine are now better protected with an extra length of conduit. 110 2.4TDCi 110 300Tdi LROCV ::: AULRO.com |
15th May 2010 11:47pm |
sasha2001 Member Since: 02 Jan 2009 Location: New Zealand+ russia Posts: 206 |
Thanks will do!! |
16th May 2010 12:20am |
The looms for the TC and ABS have been a matter of concern for several forum members, myself included. The quote below was from a historical thread from some time ago that gives details of a similar fault (I had intermittent illumination of TC and ABS lights that got progressively worse) vehicle was in twice for the fault, worth getting underneath and having a look if you've got the time and inclination.....
If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
16th May 2010 7:27am |
vogue se Member Since: 24 Jan 2008 Location: Bocholt Posts: 112 |
I had the same problem. Dealer changed both wiring kits on the rear axle...at no charge as warranty
17th May 2010 9:08pm |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
I just had a look at mine. No rubbing but they're tucked under the spring mount. If I'd been driving corrugations then I imagine they'd be rubbing pretty bad.
I've just cable-tied them by the sheath to the brake lines so all out of harm's way Thanks for the tip One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
18th May 2010 12:10pm |
ralton Member Since: 04 Feb 2010 Location: Durban Posts: 153 |
Is it this one that's supposed to be tied with a cable tie (cable tie marked as "5" in the attached)?
www.ralton.co.za |
18th May 2010 1:13pm |
Here's a couple of pics to help you identify it.
Lying on the floor behind the rear off side (RHS) wheel looking at the axle and lower spring mount. Note the cable tie. Click image to enlarge Looking down on the axle from behind the wheel. Note the ABS sensor line tied back away from the spring mount. Click image to enlarge[/img] One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
18th May 2010 3:03pm |
No problem on mine..........
I haven't ABS Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
18th May 2010 5:42pm |
I can't find the cables either. Roel
20th May 2010 7:31pm |
