Home > Technical > Check your rear ABS sensor lines
dm_td5
Australia 2008 Defender 110 Puma 2.4 SW Zermatt Silver
Installed air bag spring inserts (Polyairs) in the rear of the Puma today and whilst getting the springs in and out and cleaning everything I noted the ABS sensor lines for the rear wheels curve around the edge of the lower spring mount. This last section of the wiring is not covered by conduit and I notice it had a slight wear mark on the insulation. It hadn't worn through by a long way but it would eventually I'd guess.
I suspect this applies to both Td5 and Puma Defenders unless it is just the Puma and Ford skimping on 6" extra of conduit per rear wheel.
Suffice to say mine are now better protected with an extra length of conduit. 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #32323 15th May 2010 11:47pm
sasha2001
Russia 2008 Defender 110 Puma 2.4 CSW Tonga Green
Re: Check your rear ABS sensor lines
Thanks will do!!
Post #32324 16th May 2010 12:20am
K9F
The looms for the TC and ABS have been a matter of concern for several forum members, myself included. The quote below was from a historical thread from some time ago that gives details of a similar fault (I had intermittent illumination of TC and ABS lights that got progressively worse) vehicle was in twice for the fault, worth getting underneath and having a look if you've got the time and inclination.....
K9F wrote:
Got vehicle back, problem was with the 'rear left outlet valve' aparently the cable had been routed incorrectly since manufacture and had chaffed against an adjacent loom. Result was it was shorting out and giving me the TC and ABS captions.
Cable has since been rerouted and repaired and it will not reoccur. Even gave it a clean for me bless 'em.
K9F's got a smile on his face and no captions getting on his t1ts on his instrument cluster, happy days. For now anyway!
Thumbs Up
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #32328 16th May 2010 7:27am
Grockle
aye up Derek,haven't seen you for a while, hope ya well and thanks for the info 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #32338 16th May 2010 11:45am
vogue se
Belgium 2011 Defender 90 Puma 2.4 Exclusive HT Nara Bronze
I had the same problem. Dealer changed both wiring kits on the rear axle...at no charge as warranty Bow down
Post #32430 17th May 2010 9:08pm
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
I just had a look at mine. No rubbing but they're tucked under the spring mount. If I'd been driving corrugations then I imagine they'd be rubbing pretty bad.
I've just cable-tied them by the sheath to the brake lines so all out of harm's way Thumbs Up
Thanks for the tip One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #32453 18th May 2010 12:10pm
ralton
South Africa 2007 Defender 90 Puma 2.4 SW Zermatt Silver
Is it this one that's supposed to be tied with a cable tie (cable tie marked as "5" in the attached)?
 www.ralton.co.za
Post #32458 18th May 2010 1:13pm
alantd
Here's a couple of pics to help you identify it.
Lying on the floor behind the rear off side (RHS) wheel looking at the axle and lower spring mount. Note the cable tie.
Looking down on the axle from behind the wheel. Note the ABS sensor line tied back away from the spring mount.
[/img] One that started out as a 2.4 TDCi 110 XS
Post #32463 18th May 2010 3:03pm
dgardel
Italy
No problem on mine..........
I haven't ABS Rolling with laughter Rolling with laughter Rolling with laughter Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #32473 18th May 2010 5:42pm
roel
I can't find the cables either. Mr. Green Roel
2003 90 Td5 (2009-now)
Post #32664 20th May 2010 7:31pm
