![]() | Home > Td5 > 110 TD5 straight through??? |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8168 ![]() ![]() ![]() |
i'd keep the back box for some back pressure on a td5 Cheers
TD5 SMUT Member Since: 12 Feb 2014 Location: Worcestershire Posts: 23 ![]() ![]() ![]() |
EEERRRRm ok why is that???
help turbo Cheers
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 ![]() ![]() |
Hmmm I'd have to disagree with that sorry
110MGD Member Since: 17 Oct 2013 Location: Wear Valley Posts: 153 ![]() ![]() |
Has it been known to cause turbo problems???? If this is the case ill leave it WELL alone 2001 Td5 CSW (weekend and snow mobile) Plenty of lights, M/T tyres EGR delete, roofrack, swing away wheel carrier, snorkel.
2016 E220 CDI Night Edition Estate 2014 VW UP! 2x D3 and 1x D4 GONE |
Are you doing this just to achieve a 'raspy' sound or some other more meanigful sensible theory? Straight through centrebox and no backbox is another solution perhaps? I have that setup and it works for me. If you go through life with your head in the sand....all people will see is an ar5e!!
Fit a cherry bomb mid box, sound is meaty and raspy:
![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20616 ![]() ![]() |
Brian, may I ask who you got that from?
Steve, full stainless system from Gary at Alive.
I thought it might be but wanted to check. I expect your happy with it?
Always been happy with my dealings with Gary, you get quality that's for certain. Is yours cat back or inc a sports cat too? |
It's decat, then straight through. Surprisingly no issue with MOT in September.
So you have de-cat down pipe no cat and a cherry bomb in the middle, then straight out the rear no more silencers??
mr_tdi82 Member Since: 24 May 2011 Location: Henley on Thames Posts: 62 ![]() ![]() ![]() |
i had complete straight through no cat no middle and no back box for 6months the noise drove me and others potty,now have a cherry bomb can actually have a convo without shouting
Yes, sounds lovely under full power yet sounds OEM at tick over and low revs, but not boy racer rasp more a deep rumbling throb if that makes sense? |
