Home > Td5 > 110 TD5 straight through??? |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7886 |
i'd keep the back box for some back pressure on a td5 Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
12th Nov 2014 10:55pm |
TD5 SMUT Member Since: 12 Feb 2014 Location: Worcestershire Posts: 23 |
EEERRRRm ok why is that???
12th Nov 2014 11:05pm |
help turbo Cheers
13th Nov 2014 9:47pm |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 |
Hmmm I'd have to disagree with that sorry the turbo will give all the backpressure you'll ever need really from a performance point of view all you want to do with exhaust gas after the turbo is get rid of it
15th Nov 2014 3:20pm |
110MGD Member Since: 17 Oct 2013 Location: Wear Valley Posts: 153 |
Has it been known to cause turbo problems???? If this is the case ill leave it WELL alone 2001 Td5 CSW (weekend and snow mobile) Plenty of lights, M/T tyres EGR delete, roofrack, swing away wheel carrier, snorkel.
2016 E220 CDI Night Edition Estate 2014 VW UP! 2x D3 and 1x D4 GONE |
15th Nov 2014 3:29pm |
Are you doing this just to achieve a 'raspy' sound or some other more meanigful sensible theory? Straight through centrebox and no backbox is another solution perhaps? I have that setup and it works for me. If you go through life with your head in the sand....all people will see is an ar5e!!
15th Nov 2014 3:33pm |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
Fit a cherry bomb mid box, sound is meaty and raspy:
Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
15th Nov 2014 7:34pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20128 |
Brian, may I ask who you got that from?
15th Nov 2014 7:40pm |
Steve, full stainless system from Gary at Alive.
15th Nov 2014 7:42pm |
I thought it might be but wanted to check. I expect your happy with it?
Always been happy with my dealings with Gary, you get quality that's for certain. Is yours cat back or inc a sports cat too? |
15th Nov 2014 8:01pm |
It's decat, then straight through. Surprisingly no issue with MOT in September.
15th Nov 2014 8:07pm |
So you have de-cat down pipe no cat and a cherry bomb in the middle, then straight out the rear no more silencers??
19th Nov 2014 11:46pm |
mr_tdi82 Member Since: 24 May 2011 Location: Henley on Thames Posts: 62 |
i had complete straight through no cat no middle and no back box for 6months the noise drove me and others potty,now have a cherry bomb can actually have a convo without shouting
20th Nov 2014 12:46am |
Yes, sounds lovely under full power yet sounds OEM at tick over and low revs, but not boy racer rasp more a deep rumbling throb if that makes sense? |
20th Nov 2014 1:09am |
