Home > Puma (Tdci) > Brake Warning Light |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5111 |
Sounds like you could have a short in the wiring you will have to chase the wiring looking for a short, the second cause is low fluid level in your braking system's master cylinder. Have you ABS? If so a faulty ABS sensor is usually the culprit.
Other than that is might be ECU fault try and get a code reader attached to see if there is a fault |
10th Nov 2014 5:51pm |
Noelfar Member Since: 10 Nov 2014 Location: Mosta Posts: 2 |
I've already tried with the code reader but there were no fault codes. ok now i'll try checking out the wiring. better leave the abs thing for last. i read it also could be loose earth so better check the wiring.
Thanks a lot |
10th Nov 2014 6:37pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5736 |
Check wire from handbrake switch to loom, they can get damaged.
Andy |
10th Nov 2014 10:00pm |
V12vanquish Member Since: 28 Sep 2014 Location: Northern Ireland Posts: 52 |
Check the master cylinder switch in he cap, the float might be stuck.
10th Nov 2014 10:34pm |
schuee Member Since: 16 Jul 2012 Location: Lincolnshire Posts: 378 |
Mine did the same, took the plastic gaitor of the handbrake and the wire attached to the switch had the insulation broken and was shorting, taped up the wire, this resolved the problem.
Cheers Keith |
11th Nov 2014 3:31pm |
