Home > Puma (Tdci) > Brake Warning Light
Noelfar
Malta
Brake Warning Light
Hi there,
I have a 2010 Puma with 2.4 engine. The Brake Warning Light is always on. I've tested the handbrake switch and the oil level switch and they both work fine. Can anyone help me? The light is not flickering, just staying always on.
Thank you
Post #370810 10th Nov 2014 4:49pm
gilarion
Sounds like you could have a short in the wiring you will have to chase the wiring looking for a short, the second cause is low fluid level in your braking system's master cylinder. Have you ABS? If so a faulty ABS sensor is usually the culprit.
Other than that is might be ECU fault try and get a code reader attached to see if there is a fault
Post #370836 10th Nov 2014 5:51pm
Noelfar
Malta
I've already tried with the code reader but there were no fault codes. ok now i'll try checking out the wiring. better leave the abs thing for last. i read it also could be loose earth so better check the wiring.
Thanks a lot Very Happy
Post #370847 10th Nov 2014 6:37pm
landy andy
Check wire from handbrake switch to loom, they can get damaged.
Andy
Post #370937 10th Nov 2014 10:00pm
V12vanquish
United Kingdom 2015 Defender 90 Puma 2.2 HT Keswick Green
Check the master cylinder switch in he cap, the float might be stuck.
Post #370948 10th Nov 2014 10:34pm
schuee
Mine did the same, took the plastic gaitor of the handbrake and the wire attached to the switch had the insulation broken and was shorting, taped up the wire, this resolved the problem.
Keith
Post #371051 11th Nov 2014 3:31pm
