Home > Td5 > High pitched whistle under load
Marky Boy
Hi All,
Ok as above, another high pitched whistle question ! I have a 110 CSW with a Stage 1 Alive map and thought that my new high pitched whistle may be coming from the exhaust manifold. However, the manifold does not show any signs of soot around 1 or 5 and the nuts are all tight so no warping there. Last changed the oil 7 thousand miles ago.
I'm now inclined to think it may be coming from the drive belt / idler pulleys as it does squeak evey now and then at idle. I took the belt off at the weekend and rotated the idler pulleys by hand and there doesn't seem to be any roughness in the bearings so now at a bit of a loss other than to resort to "they all do that sir" line of thinking !
Its done 58K and I was about to do the 60K service myself as its a small one and I wanted the oil changed, can someone let me know when the belt is scheduled for replacement please or throw any ideas into the ring regarding the whistle.
Post #370806 10th Nov 2014 5:23pm
mk1collector
Could it be turbo spool up? Have you de-cat it?
Post #370815 10th Nov 2014 6:00pm
K9F
Split hose? Intercooler/turbo. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #370822 10th Nov 2014 6:21pm
redhandluke
United Kingdom 2003 Defender 90 Td5 SW Fuji White
Have you an EGR blank plate fitted? If so is all airtight?
Post #370832 10th Nov 2014 6:42pm
keith
Cracked exhaust manifold
Post #370840 10th Nov 2014 7:13pm
Tommo
United Kingdom 2006 Defender 90 Td5 Black LE Java Black
Belt replaced at 96k or 8 years Smile
Post #370891 10th Nov 2014 9:02pm
Marky Boy
Thanks for the replies, egr blank kit is fitted and looks airtight, no sign of leakage. Could be turbo spool up as the note changes with throttle position, but it's only started doing it in the last few weeks and seems to be getting more pronounced.
I'll check the hoses but was under the impression that was a Puma trait rather than a TD5 one.
Post #370893 10th Nov 2014 9:08pm
landy andy
My money is on warped manifold. I think it'll get worse then snap the studs. At this stage it's just slightly warped but enough you can't bend manifold flat with nuts, but gasket is letting gases pass.
Andy
Post #370933 10th Nov 2014 10:54pm
Marky Boy
Andy
If it turns out to be the manifold, and it's replaced, what's to stop the replacement warping as well ? Or do you get St steel one fitted ?
Post #371036 11th Nov 2014 2:43pm
mk1collector
If you get the warped one skimmed they supposedly don't warp again (so I've read)
Post #371057 11th Nov 2014 5:16pm
Phatcat
United Kingdom 2002 Defender 90 Td5 CSW Java Black
Had the very same with mine 6 months ago. It was driving me mad trying to find it. Replaced the belt and pulley, checked the manifold etc for soot, I was convinced it was worse under load, or when the turbo was spooling up. Turned out to be the rear propshaft UJ. Thumbs Up
Post #371074 11th Nov 2014 6:36pm
Marky Boy
If it's that simple I will be a happy man. I Think I'm going to end up driving it for a while until it stops working or the noise gets loud enough to work out where the problem really lies. Big Cry
Post #371154 11th Nov 2014 10:17pm
Muddybigdog
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Zambezi Silver
Just been through similar scenario turned out to be split hose turbo/inter cooler as K9 says Jumped ship to reliability - Mitsubishi L200
Puma 90 XS - Sold
D3 - 2.7 S x2 (both Sold)
Freelander 2 HSE - Sold
Freelander 1 - Sold
Disco 2 - Sold
Post #371161 11th Nov 2014 10:35pm
