![]() | Home > Td5 > High pitched whistle under load |
Could it be turbo spool up? Have you de-cat it?
Split hose? Intercooler/turbo. If you go through life with your head in the sand....all people will see is an ar5e!!
redhandluke Member Since: 02 Jun 2013 Location: Northern Ireland Posts: 243 ![]() ![]() ![]() |
Have you an EGR blank plate fitted? If so is all airtight?
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2230 ![]() ![]() |
Cracked exhaust manifold
Tommo Member Since: 19 Dec 2013 Location: Leicestershire Posts: 830 ![]() ![]() ![]() |
Belt replaced at 96k or 8 years
Marky Boy Member Since: 25 Oct 2013 Location: Maidenhead Posts: 96 ![]() ![]() |
Thanks for the replies, egr blank kit is fitted and looks airtight, no sign of leakage. Could be turbo spool up as the note changes with throttle position, but it's only started doing it in the last few weeks and seems to be getting more pronounced.
I'll check the hoses but was under the impression that was a Puma trait rather than a TD5 one. |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5804 ![]() ![]() |
My money is on warped manifold. I think it'll get worse then snap the studs. At this stage it's just slightly warped but enough you can't bend manifold flat with nuts, but gasket is letting gases pass.
Andy |
Andy
If it turns out to be the manifold, and it's replaced, what's to stop the replacement warping as well ? Or do you get St steel one fitted ? |
If you get the warped one skimmed they supposedly don't warp again (so I've read)
Phatcat Member Since: 01 Nov 2013 Location: W yorks Posts: 98 ![]() ![]() ![]() |
Had the very same with mine 6 months ago. It was driving me mad trying to find it. Replaced the belt and pulley, checked the manifold etc for soot, I was convinced it was worse under load, or when the turbo was spooling up. Turned out to be the rear propshaft UJ.
If it's that simple I will be a happy man. I Think I'm going to end up driving it for a while until it stops working or the noise gets loud enough to work out where the problem really lies.
![]() Thanks for the replies |
Muddybigdog Member Since: 11 Apr 2014 Location: Suffolk Posts: 1029 ![]() ![]() ![]() |
Just been through similar scenario turned out to be split hose turbo/inter cooler as K9 says Jumped ship to reliability - Mitsubishi L200
Puma 90 XS - Sold D3 - 2.7 S x2 (both Sold) Freelander 2 HSE - Sold Freelander 1 - Sold Disco 2 - Sold |
