Home > Puma (Tdci) > Drivetrain 'clunking'
Maml
South Africa
Hi All,
Have had a consistent issue for a while now...LR haven't able to fix it.
After driving for about 50kms (30mi), when I coast out of gear (clutch in or out, same result) it sound like the drivetrain has huge slack & makes that clunking sound generally heard before it stills.
Happens from about 2000rpms downwards, and from about 40kph (25mph) to standstill.
LR have adjusted the handbrake drum thingy's (first try), and recently replaced some input/output shaft (second try). It still however makes the sound.
I'm on about 61kkms (38k miles). 2012 D130 2.2.
Any help would be much appreciated. The loan Freelanders and Evoques are nice, but I want my Defender back!
Thanks in advance.
Mike
Post #370273 8th Nov 2014 7:03am
LR90XS2011
does it do it if you slow down in neutral if it does it sounds like the symptom of the brake drum adjustment. To test the hand brake theory when it is doing it and you are slowing down in neutral very very gently apply the hand brake so it just drags (do not yank it on you may break something) if the noise stops it points to the hand brake or at least it was with mine. Alternatively wind the hand brake right off and see it the noise goes away. If the noise has gone away when in neutral but does it when in gear it would point more to an issue in the drive line, has it done it since new? DEFENDER 90 TDCI XS,
Post #370274 8th Nov 2014 7:08am
Maml
South Africa
Will try the gentle application of handbrake - only recently started doing it.
Hopefully it's an adjustment issue...only happens when in neutral.
How do I wind it off? Sounds like the best option, as I hardly use it anyway for daily stuff.
Post #370283 8th Nov 2014 7:40am
kimhas
Norway 2011 Defender 110 Puma 2.4 X-Tech LE Nara Bronze
I have / had the same problem as you. And as you say, only in neutral. But I am 95% shure my problem was the handbreak. Only comes aftes some driving so things are little hot.
I am not shure why the problem only is in neutal but I think it may have something with the forces affecting driveline.
Not so easy for me to write in english , sorry Smile
Kim MY2011 Defender 110
Post #370288 8th Nov 2014 8:05am
sparkylee
2012 Defender 110 Puma 2.2 DCPU Santorini Black
Mine used to do it after a longish drive and was handbreak Thumbs Up It's good to be back from the dark side
DC110 -2012 Black with black hood and black x-tech
FFRR 4.2 vogue
Renault traffic auto
PT crusier convertible
Laika x700 Motorhome
Post #370291 8th Nov 2014 8:28am
Rickydodah
In my opinion the approved adjustment procedure gives insufficient clearance and slack in the system. What I've done in the past to cure this problem is to adjust per manufacturers spec and then back off the adjuster on the drum to give 3 clicks on the lever to apply and 4 just achievable. Brake linings do have a porousity and even living in low lying and coastal areas with a heavy atmosphere will swell the linings and corrode the drum leading to grabbing and the inevitable drive line snatching.
Thumbs Up
Post #370309 8th Nov 2014 10:25am
LR90XS2011
If it only does it in neutral it is most probably just hand brake adjustment, as others have said they tend to do it more after a bit of a run, backing off the handbrake should cure it, mine was adjusted at its first service and has been fine ever since, there are several threads on here re the issue, good luck DEFENDER 90 TDCI XS,
Post #370343 8th Nov 2014 3:00pm
Maml
South Africa
Thank you for all the input - waiting on LR to respond.
Post #370993 11th Nov 2014 9:41am
Sign of the transfer box driveshaft splines wearing??
Post #371003 11th Nov 2014 10:16am
