Home > Technical > leaking gearbox?
tookaphotoof
Netherlands 2013 Defender 130 Puma 2.2 HCPU Santorini Black
leaking gearbox?
I had the dealer check it before I left for my holiday in July and was told the car was fine.
Still, no matter how often I clean up the oil underneath, it keeps coming back. Do they all do that?
As far as I can remember I never had this problem with any of the BMW's I had in the past but you never know. Maybe I'm just getting a bit paranoia after the many visits to the dealership...
(puma 2.2)
Post #364422 14th Oct 2014 3:12pm
No, it shouldn't do that. It's either gearbox oil leaking out of the front of the box (possible if it's been overfilled like many are), sump oil from the crankshaft rear main oil seal, or clutch fluid from the slave cylinder.
Post #364469 14th Oct 2014 6:32pm
tookaphotoof
Thanks, in that case I'll have the dealer have a look into it. Thumbs Up
Post #364471 14th Oct 2014 6:39pm
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
It shouldn't leak. I assume as it is a 2.2 it is still under warranty so take it to the dealer.
I had similar leak (though not a bad as that) fixed under warranty. It took them a couple of attempts - first they fitted a new slave cylinder and clutch. The second time involved changing Rear Crank Oil Seal, Gaskets for Upper and lower sump and Front timing casing.
Post #364573 15th Oct 2014 7:25am
Newsey
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Corris Grey
i've just got mine (MY13 2.2) back from the dealer after warranty work to correct a leak that looks very similar to yours. It turned out to the crankshaft seal. It wasnt the actual seal but the mounting plate for the seal. This has two spots of sealant placed were it sits against the ladder frame. Only one sealant spot was present Shocked Good old Ford! I agree let the dealer have a look asap. It will be interesting if yours turns out to be the same.
Post #364577 15th Oct 2014 7:40am
