Home > In Car Electronics > Aftermarket stereo upgrade
Beefcake
United Kingdom 2010 Defender 110 Puma 2.4 USW Stornoway Grey
Hi Everyone
I'm new to defender ownership, so am learning loads from the forum (thanks, very helpful). Hopefully you can help me again!
I had to change the battery in my 2010 defender, and the standard head-unit that was fitted, is not the original one which fitted to the vehicle when it left the factory. Subsequently my stereo is now locked (note to self, always check serial number on stereo rather than accept what is in the owners handbook).
Any way, rather than pay 18 to the main dealer, I decided to upgrade the head unit to a natty little alpine unit. Reserved it online and nipped down to Halfords to pick it up. I asked for a corresponding ISO lead as well, which was when the Halfords chap spooked me with the fact that it's quite possible my defender is fitted with a OE amplifier, and if I plug in an aftermarket stereo with ISO leads, then there is a good chance I'll blow the amplifier and be landed with a hefty bill from Land Rover to get rectified? He believed it was common on Range Rovers etc, so likely to be the same on the defender.
I'm proficient with car audio, but am not familiar with a lot of the quirks associated with owning a defender, so am concerned that swapping out the standard stereo for something aftermarket, could land me with an unexpected bill. I see that loads of owners on the forum have swapped to aftermarket units, so is it just a case of plug and play, or is there some truth in what I've been told?
Thanks for your help.
Beefy
Post #362630 6th Oct 2014 2:01pm
TDCi Guy
United Kingdom 1996 Defender 110 300 Tdi HCPU Auto Keswick Green
Defenders only have an amplifier if they also have the subwoofer which is mounted on the back of the cubby box. Thumbs Up Tom
@tditomprice
100” Defender Hybrid
2010 Alaska White 90 HT
Post #362633 6th Oct 2014 2:10pm
ISO wiring on a 2010 it's only 2012 onwards where you need an adaptor.
You should find it's plug and play.
Post #362636 6th Oct 2014 2:33pm
Venomator
Or, in my case, behind the passenger seat... Thumbs Up  Rog... Mr. Green
The GREEN One...
MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color]
Post #362637 6th Oct 2014 2:35pm
Tiger
Wot he said. Thumbs Up
Post #362643 6th Oct 2014 3:05pm
Beefcake
Thanks everyone. Much appreciated!
Post #362681 6th Oct 2014 6:03pm
