Home > Td5 > TD5 immobiliser |
Super7 Member Since: 05 Feb 2014 Location: South Bucks. Posts: 132 |
Well I've just had a good look around inside the shroud and behind the dash. It looks like there is no exiter ring fitted either Would I need to get one of these before activating the immobiliser?
5th Oct 2014 5:22pm |
mine has been working ok with out coil years
5th Oct 2014 5:33pm |
Nice one, cheers
5th Oct 2014 5:37pm |
achuakh Member Since: 12 Apr 2012 Location: Singapore Posts: 158 |
don't need the exciter ring or the transponder coil. It's there to make life easier if the passive immob has been activated (red light on) and you try to start the engine, the transponder will send out a signal to the fob to send its unlock code.
if this is not there, the immob lamp will flash and you will have to manually press unlock on the fob before you can start the engine. any 10AS box can be transformed into one with central door locking by installing a relay, NEC EP2 3N1S. Land Rover scrimped on this and didn't have those fitted on the ones speced without CDL. With this relay in place, you will get 12v or -12v on pin 2 and 3 (green connector) when you press lock / unlock. this is used to drive the door lock motors directly. So if you can hold a solder and a sucker or wick you can easily accomplish this by opening up the box and soldering this onto the PCB. From the land of the most expensive land rover defenders on planet earth. At �125k for a XS 110 csw and you get to own it only for 10yrs! Please find me a good reason to stay on this island. |
13th Oct 2014 12:41pm |
That’s good to know, thanks
There seems to be quite a few options for configuring the alarm – does anyone know of any information available listing what they are and what they do? |
14th Oct 2014 12:10pm |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2237 |
www.nanocom-diagnostics.com/downloads/1691879270.pdf 02' 110 TD5 Double Cab Rebuild Thread
14th Oct 2014 1:35pm |
Perfect, thanks Steve!
14th Oct 2014 1:47pm |
